Understanding Body Diagonals of a Cube
  • Thread starter Thread starter Disar
    Body Cube
The discussion revolves around understanding the body diagonals of a cube and finding the angle between them. Participants express confusion about the definition of body diagonals and their geometric properties.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Some participants attempt to clarify what body diagonals are and how they relate to the geometry of the cube. Others share their experiences with visualizing the diagonals and the angles between them. There are questions about the correct method to calculate the angle using vectors and the implications of using different points for the diagonals.
The discussion is ongoing, with various interpretations being explored. Some participants have provided insights or attempted to clarify concepts, while others continue to seek assistance in understanding the problem. There is no explicit consensus on the correct approach or answer yet.
Participants mention using a unit cube and refer to specific coordinates for the diagonals. There is also a mention of guidance from a professor regarding the representation of the diagonals, indicating that assumptions about the setup may be under discussion.
Disar
Can anyone out there tell me what the body diagonals of a cube are.
I am asked to find the angle between the body diagonals of a cube. Seeing as how it is just the application of the dot product it does not seem difficult other than I do not know what body diagonals are (I have an idea but would like to know from someone for sure).
Found it! The body diagonals of a cube are the from one point on a cube to the next and the angle between them is 90 degrees (they bisect one another)
Should of looked first
I have the same problem, yet, I still can't picture it.
slice the cube through the intersecting diagonal... the shape that is left is like an "incline plane". or imagine a table with square top, and square sides and square base with the legs intersecting.
It's the thing in these pictures:
http://library.thinkquest.org/22494/images/cubi.jpg
http://www.mathaware.org/mam/00/master/essays/B3D/2/JPG/figure16.jpg
In the second picture, it's the "longer diagonal".
I seem to be getting an answer of 45 degrees which isn't right...
When drawing the vectors in the case within the cube, do they have to be from the same origin?
nvm, thanks for your help~!
Did you get the correct answer?
i used a unit cube.
with one diagonal at (0 0 1) (1 1 0)
the other diagonal at (0 0 0) (1 1 1)
but it doesn't work, hmmm...for a sec i thought i did get it.
overseastar said:
i used a unit cube.
Good, now find the vectors describing the diagonals using the vectors given above, representing their end-points.
What do you mean by "it doesn't work"? What doesn't work?
The answer written by Disar is incorrect.
oh, if that's the case, I think I got it LOL Thanks a bunch!
I went to my professor about this problem and he told me to use A=x+y+z and B= -x+y+z, naming one of the body diagonals A, and the other body diagonal B. I'm a bit confused how to take the 4 points above to make them fit the A and B my prof gave me. Can anyone help me with this please?? Thanks
Can you help me? I still don't get it, thanks
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 19 ·
