How Far Does the Spring Compress When a 20 kg Mass Slides Down an Incline?
The problem involves a 20 kg mass sliding down an incline at a 30-degree angle, interacting with a spring at the bottom. The mass experiences friction, and the spring has a specific spring constant. Participants are tasked with determining various aspects of the motion and energy transformations involved as the mass interacts with the spring.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using energy equations to relate kinetic energy, potential energy, and work done by friction. There are questions about how to apply these concepts to find the spring compression and maximum velocity.
Some participants have provided guidance on using energy equations to approach the problem, while others express uncertainty about specific calculations and how to apply results to subsequent questions. There is an ongoing exploration of the relationships between energy forms and the mechanics of the system.
Participants are working under a time constraint to complete the assignment, and there is mention of needing to clarify the force applied to the spring and how to find maximum velocity. The discussion reflects a mix of attempts and uncertainties regarding the application of energy principles.
accc
A 20 kg mass is released from rest at the top of a plane inclined at an angle of 30 degrees. At the bottom of the plane lies a spring with a spring constant of 200 N/m. The distance between the mass and the spring is 6 m, and the coefficient of sliding friction is .2. I have to answer a series of questions:
a) How far has the spring been compressed when the block is brought to rest?
b) What is the velocity of the mass as it reaches the spring?
c) & d) How far will the spring be compressed when the mass reaches its maximum velocity, and what will its maximum velocity be?
e) What is the velocity of the mass as it is released by the spring back up the plane?
f) How far up the plane does the mass travel?
g) How long does it take for the mass to reach this point?
This was originally assigned a while ago, but I never got around to doing it and I have to hand it in by tomorrow. I came up with an answer for the second question by doing Kinetic Energy + Work done by Friction = Potential Energy, but I'm not sure if that's the right way to do it. I need help on the first question with finding how much force is being applied to the spring, and also for the 3rd and fourth questions on how to find the maximum velocity. After I find these I could probably do the last three questions by myself. Can anyone help?
For a & b, I would use the so-called energy equation: the (negative) work done by friction equals the change in energy of the mass. (Be sure to include all applicable energy forms: gravitational PE, spring PE, and KE.)
For c & d, I would use the same energy equation to express the KE as a function of spring compression. Then I would differentiate, to find the compression for maximum KE. Once you have the spring compression, you can find the KE and velocity.
Hope this helps a bit.
I'm pretty sure that's what I did for b. I did 1/2mv^2 + umgcos30*d = mgh. With units, I came up with 10v^2 + (.2)(20)(9.8)(cos30)(6)=(20)(9.8)(6sin30), and came up with v = 6.2. Now I'm not sure how I apply this to question a, for how far the spring is compressed when v = 0?
Yeah after I find out how far the spring gets compressed in a I'm pretty sure I can figure out the rest. Thanks for your help.
I didn't check your arithmetic, but your equation looks good to me. For question a, do the same thing. Only now the KE is zero and you have some compressed spring energy.
Okay, I got it now. Thanks!
  • · Replies 27 ·
11K
