Finding the Final Speed of a Golf Ball Projected at an Angle
The discussion revolves around a physics problem related to projectile motion, specifically focusing on determining the final speed of a golf ball projected at an angle. The original poster presents a scenario where a golf ball is struck with an initial speed and lands at a lower elevation, prompting questions about the necessary information and methods to solve for the final speed.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various methods to approach the problem, including conservation of energy and analyzing the x and y components of velocity. Some express confusion regarding the lack of an angle of projection and question how to derive the components without it.
The discussion is active, with participants offering different perspectives on how to tackle the problem. Some suggest using kinematic equations to find the final velocity components, while others express uncertainty about the implications of not knowing the angle of projection. There is no explicit consensus, but several lines of reasoning are being explored.
Participants note the absence of certain information, such as the angle of projection, which complicates the analysis. The problem is framed within the constraints of a homework assignment, which may limit the methods available for exploration.
Ihsahn
Ok, having studied projectiles over the past few weeks, reaching the "Equation for the path of a projectile stage," I've been presented with the following question. As far as I can see, there isn't enough info to answer the question (unless, of course, its one of those simultaneous equation ones, or I've missed something obvious)
A golf ball is struck from a point O, leaving O with a speed of 21 root 2 m/s. The ball lands, without previously bouncing, at a point A, which is 10 metres below the horizontal plane through O. Find the speed of the ball at the instant it lands at A
In the question, g (Gravity) is taken to be equal to 9.8m/s^2...
Any help would be much appreciated!
There are several ways to solve this. If you've covered conservation of energy, use it.
Assuming you haven't, then considered the x and y components of the velocity separately. And realize that [itex]V^2=V_x^2+V_y^2[/itex].
Excuse me, but I'm not familiar with the expression 21 root 2. What is it?
Sorry if that was unclear, I meant 21 multiplied by the square root of 2.
Doc Al, I don't quite follow... we haven't covered conservation of energy... and I'm unsure how to obtain the x and y components given that we have no angle of projection? Forgive me if its something obvious or simple.
Thanks.
You don't have to know the angle. Call the components [itex]V_x[/itex] and [itex]V_y[/itex]. Now write down the final values of those velocity components. Try it and see what you get. (Hint: Use [itex]V_f^2=V_i^2+2as[/itex].)
Again, sorry if this sounds stupid;
We've always evaluated (for example) [itex]V_x[/itex] as [itex]V cos[/itex] a and [itex]V_y[/itex] as [itex]V sin[/itex] a ??
The only thing I can think of from your suggestion is the use of trig identities? Do they play a part?
I'm obviously missing something...
No trig needed. Do you agree that [itex]V^2=V_x^2+V_y^2[/itex]?
So do the following...
1) Find [itex]V_{y,f}^2[/itex] in terms of [itex]V_{y,i}[/itex], [itex]a[/itex], and [itex]\Delta y[/itex] using the kinematic equation given earlier.
2) Realize that [itex]V_x^2[/itex] is a constant.
3) Add these to get [itex]V_f^2[/itex].
A solution (I think )follows. If you don't want to see it, ignore this post.[/color]
Denote the initial velocity of the golf ball [tex]V_{0}[/tex] and the final velocity [tex]V[/tex].
We have a relation
[tex]V_{0}^2 = V_{x0}^2 + V_{y0}^2[/tex].
Substituting [tex]V_{0} = 21 \sqrt {2}[/tex],
we have
[tex]882 = V_{x0}^2 + V_{y0}^2[/tex].
Therefore,
[tex]V_{y0}^2 = 882 - V_{x0}^2[/tex].
Ignoring the effect of friction, the [tex]x[/tex] component of the speed of the golf ball remains unchanged throughout its flight.
Thus,
[tex]V_{x0} = V_{x}[/tex].
The [tex]y[/tex] component of the final speed of the golf ball upon landing is obtained from the following relation:
[tex]V_{y}^2 = V_{y0}^2 + 2g (10 \mbox{m})[/tex]
[tex]= (882 - V_{x0}^2) + 196[/tex]
[tex]= 1078 - V_{x0}^2[/tex]
[tex]= 1078 - V_{x}^2[/tex].
[tex]V^2 = V_{x}^2 + V_{y}^2[/tex]
[tex]= V_{x}^2 + (1078 - V_{x}^2)[/tex]
[tex]= 1078[/tex].
[tex]V = \sqrt {1078}[/tex]
[tex]= 32.83 \ \mbox{m/s}[/tex]
  • · Replies 19 ·
  • · Replies 22 ·
