Calculate Resultant Force of Charges on Rectangle
The discussion revolves around calculating the resultant force on a positive charge located at one corner of a rectangle, with four charges positioned at each corner. The dimensions of the rectangle and the charge value are provided, but the focus is on understanding the force interactions between the charges.
  • The original poster attempts to calculate the force components in the X and Y directions based on the geometry of the rectangle and the positions of the charges. Some participants suggest adding the components from different corners to find the resultant force. There are questions about the correct method to combine these forces and how to calculate the final resultant force.
Participants are engaged in exploring the calculations needed to find the resultant force. Some guidance has been offered regarding the addition of force components, but there is no explicit consensus on the final approach or solution. The original poster expresses urgency due to an impending deadline.
The original poster mentions a homework deadline, indicating time constraints that may affect the depth of exploration in the discussion. There is also a sense of frustration regarding the complexity of the calculations involved.
Alt+F4
http://img424.imageshack.us/img424/6972/showmeks9.gif
Four charges are placed on the corners of a rectangle. What is the resultant force on the positive charge (a = 1.1 m, b = 0.7 m, q = 2.4 × 10-9C)?
So you need to break this into X and Y, for Hypotnuse i got 1.303
So wat i did was
Ex1 = K(2.4*10^-9) * Cos 32.47 / (1.303)^2 = 10.286
EY1 = K * 2.3*10^-9 * sin 32.47 / (1.303)^2 = 6.545
For Ex2 and Ey2, the answers should be the same
I am trying to find |F| , i know after i get Ex and Ey i will multiply this by 2.4*10^-9 and do X^2+Y^2 and take the square root
How do i get F. Thanks
You've apparently found the X-Y components of the force due to the
charge at the opposite corner of the rectangle. Just add these
components to the X-Y components of the forces due to the charges at the adjacent corners of the rectangle. Then find the resultant of the total X-Y components of the forces just found.
Ex = K(2.4*10^-9) (1.1)^2= 17.851
EY = K * 2.4*10^-9 / (.7)^2 = 44.081
Hw is due in an hour, i have tried everything
  • · Replies 25 ·
10K
