General Relativity + Electrodynamics
The discussion revolves around the interaction between general relativity (GR) and electromagnetism (EM), specifically focusing on the behavior of charged black holes, such as the Reissner-Nordström black hole, and the implications of electric fields in curved spacetime. Participants explore both classical and semiclassical approaches to these concepts, raising questions about the nature of forces, field lines, and the behavior of virtual photons near event horizons.
  • One participant questions whether the force on a singularity due to an external charge changes when the charge is moved further away, suggesting a dependence on the solid angle of geodesics.
  • Another participant introduces the idea that virtual photons may travel faster than the speed of light, referencing Feynman's work, but expresses uncertainty about its relevance to the semiclassical questions posed.
  • A third participant discusses the electric field of a Reissner-Nordström black hole, emphasizing the use of Gauss's law and local frames to compute the force exerted on a test charge.
  • Further elaboration on the "field line" approach is provided, noting that the representation of electromagnetic fields is independent of spacetime curvature, but the metric plays a role in converting between different tensor forms.
  • One participant expresses interest in the electric field due to an external charge near the singularity, indicating a desire to clarify the relationship between geodesics and field lines.
Participants do not reach a consensus on several points, including the implications of moving charges on the force experienced by the singularity and the role of geodesics in understanding electric fields in curved spacetime. Multiple competing views and interpretations of the semiclassical aspects remain unresolved.
The discussion highlights limitations in understanding the behavior of electric fields in curved spacetime and the complexities involved in relating classical and semiclassical theories. There are unresolved questions regarding the nature of virtual photons and their interactions with black holes.
JustinLevy
GR and EM are classical field theories, but later in the questions I wish to treat this in a semiclassical manner. For those helping to answer, please be specific which answers can be done in a purely classical manner, and which require quantum approaches (and please let me know if the semiclassical approach will not apply to some of these questions, such that we must wait for a consistent quantum gravity theory).
Let us consider a non-rotating black hole with charge (Reissner-Nordström black hole) and also consider another charge slightly above the event horizon. For roughly 4pi of the solid angle, geodesic lines for light starting from this external point will terminate at the singularity. Let's define F as the force on the singularity due to this external charge at this distance.
If I now move the external charge further away, so that the solid angle (of geodesic lines starting from this external point and terminating at the singularity) is now pi, will the force now be F/4 as intuition suggests? (a kind of "number of field lines" idea of electric field strength)
If so, does this mean the force on the singularity due to an external charge located at the event horizon is independent of the event horizon radius?
Now, while almost the entire solid angle of geodesics from a point above the horizon meet the singularity, only a small fraction of the total solid angle of geodesics meeting at the singularly actually go through the external point. So does this mean the electric force on the singularity will be greater than the electric force on the external charge?
This seems wrong to me. So, while making the explanation of the 1/r^2 in Coulomb's law seem obvious in flat space, the "number of field lines" idea of electric field strength probably doesn't work in curved space for some reason? If so, can someone explain this to me?
Now for the semiclassical part: How can we even know a black hole is charged? In other words, how can the virtual photons escape the singularity and leave the event horizon? I realize they can have a spin-0 state or even non-zero invarient mass, unlike normal photons, so can they do other bizarre things like travel "faster" than the speed of light?
I have many other questions as well, but I need to clear up any of my possible misunderstandings of this first before I can hope to move on to the rest.
To answer a tangent question from above, apparently virtual photons can travel faster than the speed of light. Richard P. Feynman QED:(QED (book)) p89-90 "the light has an amplitude to go faster or slower than the speed c, but these amplitudes cancel each other out over long distances".
Whether or not that actually helps answer the semiclassical part of the questions above is another issue though. I have a feeling it doesn't, but if someone could say for sure that would be nice.
Let's consider just a small subset of this question, the question of what the electric field of a Reissner-Nordström black hole (RN black hole) is.
There are several ways of approaching this. One way uses "differential forms", which is the mathematical justifiation for counting "field lines".
The question is best posed as "what is the force exerted by the RN black hole on the test charge". That's what one can actually compute, after all.
If we set up a local frame, the field line argument, or a more sophisticated analysis will show that the intergal of the local force multiplied by the local area is always equal to the enclosed charge (Gauss law).
Note that this uses the local clocks and rulers at some particular distance 'r'. Note also that this won't work for gravity in the same manner, I can go into how that works if there is interest.
The more sophisticated analysis would come to the same conclusion. A more sophisticated analysis proceeds as follows. One sets up the RN metric as an orthonormal basis (ONB) of one-forms:
w1 = (Z,0,0,0)
w2 = (0,Z,0,0)
w3 = (0,0,r,0)
w4 = (0,0,0,r sin(theta))
where Z = sqrt(1-2M/r+Q/r^2)
plus use the vector potental expressed in terms of the coordinates
Aa = (Q/r,0,0,0)finds the Faraday tensor in terms of the coordinates
[tex] F_{ab} = A_{a;b} - A_{b;a}[/tex]
Checks the solution to verify it satisfies Maxwell's equation
[tex]F_{ab}{}^{;a} = 0[/tex]
and then converts F into the "basis vectors" or frame field given by the ONB of one-forms, i.e compute
[tex]F_{\hat{a}\hat{b}}[/tex]
Either way, one winds up with the result that F=Q/r^2 in the local coordinate system of the charge.
I don't believe offhand that the force is always the same at the horizon, though.
Geodesics don't have anything to do with calculating the force - charge can be expressed by Gauss's law and the spherical symmetry of the problem. The "field line" argument is the easiest way to show that local normal force * local area is a constant equal to the enclosed charge.
Let me see if I can try and describe the "field line" approach a little more rigorously.
The electromagnetic field can be represented by either of two equivalent tensors, the Farday tensor F and its Hodges dual, the maxwell tensor, also called M.
"Field lines" raditing from a charge actually best represent *F, the Maxwell tensor.
The basic field line representation is independent of the curvature of space-time, the only place the metric really plays a role is in coverting F into its dual M, and vica-versa. Vacuum solutions of Maxwell's equations are represented by continuous field lines which don't "break". To have a source or sink of field lines, one must have charge.
Counting field lines penetrating an oriented surface to get a scalar can be thought of as defining a two-form. The oriented surface is defined by two vectors. The direction of penetration which is considerd to be "positive" is specified by the orientation of the surface, which is specified by the order of the two vectors. Two forms are anti-symmetric rank 2 tensors.
The act of counting field lines only gives the force when one is in a locally Minkowskian (i.e. orthonormal Lorentz) frame. One might intuitively guess the need for a Minkowskian frame - certainly the magnitude of the force should depend on the particular scale chosen for time, and the area of the surface and the number of lines penetrating it do not depend on the scale chosen for time.
More formally, when one counts field lines, what one is really doing is taking the dual of a two form, then using the "natural" integration operation associated with two-forms on two dimensional manifolds to get a scalar.
http://en.wikipedia.org/wiki/Differential_forms#Integration_of_forms
This process of taking the dual is where the metric coefficients (specifically the choice for the time scale, g00) enter. The need for dealing with the metric coefficients can be eliminated, as mentioned previously, by always using locally "Minkowskian" frames for all the tensor quantities.
Wow, thank you again for the extensive reply. You really help make this place great!
Yes, but as you mentioned, the symmetry of the problem makes this one simple and therefore not very interesting. Besides the semiclassical question, I was really more interested in the electric field due to the external charge in the vicinity of the singularity.
I was using the geodesics to "follow" the field lines. If we consider all the geodesics for light going through the external point, initially they are "eminating" in a spherically symmetric pattern in the local region of the external point. If space was flat, their "flux" would fall off as 1/r^2. However, due to the curvature of space in the case of the external charge, they don't remain "equally dense" (we lose the spherical symmetry). And of course for the case of the charge at the singularity, if we consider all geodesics for light going to this point, their "flux" will retain spherical symmetry at all distances from the singularity.
So why wouldn't the "flux" of such geodesics also match the "flux" of the field lines? Is there another way to visualize the field lines "curving"?
I have seen the "Hodge star" notation only briefly in discussion of Maxwell's equations before, but I really am not knowledgeable in differential forms yet. So I'll have to read up more on the ideas to get a feel for this. I'll have to learn it eventually anyway if I want to really learn GR.
Thank you again for your responses, it is very much appreciated. Do you happen to know anything about my semiclassical question as well? (How can virtual photons leave the singularity and escape the event horizon so that the Coulomb force may be felt from the charge at the singularity?)
Well, back to reading...
Geodesics and field lines are two different things. You are taking the virtual particle idea a bit to literally.
For instance, using your approach, one would expect that the direction of force between two charges in flat space-time would be towards the charges 'retarded' position.
But the actual coloumb force always points at the 'current' direction, not the retarded position.
See for instance http://math.ucr.edu/home/baez/physics/Relativity/GR/grav_speed.html
Since this point can be confusing, it's worth exploring a little further, in a slightly more technical manner. Consider two bodies--call them A and B--held in orbit by either electrical or gravitational attraction. As long as the force on A points directly towards B and vice versa, a stable orbit is possible. If the force on A points instead towards the retarded (propagation-time-delayed) position of B, on the other hand, the effect is to add a new component of force in the direction of A's motion, causing instability of the orbit. This instability, in turn, leads to a change in the mechanical angular momentum of the A-B system. But total angular momentum is conserved, so this change can only occur if some of the angular momentum of the A-B system is carried away by electromagnetic or gravitational radiation.
Now, in electrodynamics, a charge moving at a constant velocity does not radiate. (Technically, the lowest order radiation is dipole radiation, which depends on the acceleration.) So, to the extent that A's motion can be approximated as motion at a constant velocity, A cannot lose angular momentum. For the theory to be consistent, there must therefore be compensating terms that partially cancel the instability of the orbit caused by retardation. This is exactly what happens; a calculation shows that the force on A points not towards B's retarded position, but towards B's "linearly extrapolated" retarded position. Similarly, in general relativity, a mass moving at a constant acceleration does not radiate (the lowest order radiation is quadrupole), so for consistency, an even more complete cancellation of the effect of retardation must occur. This is exactly what one finds when one solves the equations of motion in general relativity.
Here you are (so far) only worried about the electrostatic case and can ignore the remarks about gravity.
Basically, you need to review how you calculate force, your model of how virtual particles carry forces is too literal and flawed. Virtual particles aren't real particles, they don't travel along definte paths. The fact that the coloumb force doesn't aberrate is a typical error resulting from assuming just what you've been assuming.
I don't work with QM much, you might try http://math.ucr.edu/home/baez/physics/Quantum/virtual_particles.html
The moral is that the lines in a Feynman diagram are not to be interpreted literally as the paths of classical particles. Usually, in fact, this interpretation applies to an even lesser extent than in my example, since in most Feynman diagrams the incoming and outgoing particles are not very well localized; they're supposed to be plane waves too.
for a short example of the correct way to get forces out of QM via virtual particles as "plane waves". Treating them as actual particles gives wrong answers, though. You might also try the QM forum for more details. I'm afraid I can't help much here, I never really got into the "forces as virtual particles" paradigm in a manner that I can use it to do anything useful. I've seen enough about it to know that it's trickier than the popularizations would have one believe.
The approach I'm using is based on differential forms. This is discussed in detail in MTW's "Gravitatio". Online, I find.
http://www.ee.byu.edu/forms/forms_teaching_warnick.pdf
You might try looking around Physics Forums too I think someone was writing a series of notes about differential forms here.
The field lines are a graphical way of representing these differential forms. If you know something about tensors, differential forms are just completely anti-symmetric tensors. The Faraday tensor is an example of a differential form, of rank 2, because it is a rank 2 anti-symmetric tensor.
You don't absolutely need differential forms to understand GR, but it helps. It's
You might try
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/black_gravity.html
but the answers there aren't totally satisfying. It might help, though, to think about how the coulomb force works in flat space-time. Remember, that I mentioned earlier that it always points towards the "current" position (actually the linearlly extrapolated position) of a moving particle.
How do you "explain" this direction of the Coulomb force? You can go the "virtual particle" route, but I never really got into that much as I mentioned eariler.
You can use "Lienard Wiechert" potentials. You don't retard forces, directly, but if you retard the potentials, you can get the right answers.
You can also use the Coulomb gauge. Here the force just points directly towards the charge. The good news is that its easy to work with. The bad news is that this hides the underlying Lorentz invariance of electromagnetism - it looks like "action at a distance".
  • · Replies 43 ·
  • · Replies 57 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 22 ·
