Net force on charges found to be zero
The discussion centers on the electrostatic principles related to net forces on charges, specifically when a positive point charge +q is placed near two other charges, A and B. It is established that for the net force on +q to be zero, the forces exerted by A and B must balance each other. The analysis involves applying Coulomb's law to determine the relationships between the magnitudes and signs of the charges A and B. Key conclusions include that if A is negative, B must be positive, and if A is positive, B must be negative for equilibrium.
  • Coulomb's Law
  • Understanding of electrostatic forces
  • Basic principles of charge interactions
  • Knowledge of charge sign conventions
  • Study Coulomb's Law in detail
  • Explore the concept of electric field and potential
  • Investigate the superposition principle in electrostatics
  • Learn about charge distribution and its effects on net force
Students of physics, educators teaching electrostatics, and anyone seeking to understand the principles of charge interactions and net forces in electrostatic systems.
eltel2910
I'm having trouble understanding some of these basic electrostatic priciples and my book isn't much help. I've put them in a true/false format. If I could get at few answers, it would really help me understand this.
A positive point charge +q is placed at point p to the right of two charges, A and B. The net force on the +q charge is found to be zero. Which of the statements below are true?
A-----------B-----------P
++++++++++++++++++++q
True or False -- The magnitude of the charge A must be smaller than B.
True or False -- Reversing the sign of +q to -q would make the force on it nonzero.
True or False -- B must have the same sign as A and be less in magnitude.
True or False -- B must have the opposite sign from A and be less in magnitude.
True or False -- Either A or B must be positive.
Welcome to PF eltel.
What are your thoughts on how to go about solving the questions ?
Start from the basics, namely Coulomb's law .
I eltel,
you must analyse two cases:
A negative then B must be positive so that the net force be zero on p.
A positive then B must be negative...
Then use Coulomb's law to complete your reasoning.
  • · Replies 21 ·
  • · Replies 19 ·
