Thread Closed
Beam Deflection
Share Thread Thread Tools
Sep5-06, 02:34 PM   #1
Beam Deflection
Ok I was given this problem:
Problem: The deflection d of a cantilever beam of length L is given by the mechanics of materials equation [tex]d=PL^3/3EI[/tex]
Where P is the force on the end of the beam and E is the modulus of elasticity, which has the same dimensions as pressure.Determine the dimensions of I which is the moment of Inertia.
Are they simply asking you to manipulate the equation for I? If so would the following be correct? A little help would be appreciated, thanks.
[tex] I= 1/d(PL^3/3E)[/tex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep5-06, 03:07 PM   #2
Any help appreciated.
Sep5-06, 07:50 PM   #3
Recognitions:
Homework Helper Homework Help
is this a dimensional problem?, like stress is F/L^2, in a gravitational system (FLT)
Sep6-06, 06:26 PM   #4
Recognitions:
Beam Deflection
Generally, we define the moment of inertia for a rigid body as [tex]\int_{V} r^2 \rho dV = \int_{V} r^2 dm[/tex], so the dimension is [kg*m^2]. But, in mechanics of materials, we define the axial moment of inertia of a cross section with the area A, as [tex]\int_{A} r^2 dA[/tex], where r is the perpendicular distance of the elementary area dA to the axis for which the moment of inertia is defined, so, for example, we have [tex]I_{z}=\int_{A} y^2 dA[/tex]. So, the dimension is [m^4], which fits into your problem of expressing I out of d = PL^3 / 3EI.
Thread Closed
Thread Tools
Similar Threads for: Beam Deflection
Thread Forum Replies
beam deflection Introductory Physics Homework 5
Beam deflection General Engineering 4
Beam deflection Engineering, Comp Sci, & Technology Homework 12
I-Beam deflection Mechanical Engineering 6
