Solving Limits: Seeking Help with x Approaching 0
  • Thread starter Thread starter vgower
    Limits
The discussion revolves around evaluating two limits as x approaches 0: the limit of sin^2(4x) / (x tan(x)) and the limit of (x + tan(4x)) / sin(9x). Participants express uncertainty about the methods to solve these limits, noting that they are not undefined.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Some participants suggest using L'Hospital's rule, while others indicate that they are not yet studying derivatives. There are attempts to break down the expressions using trigonometric identities and properties of limits, particularly the limit of sin(x)/x as x approaches 0.
Participants are exploring various methods to approach the limits, with some expressing that they arrived at the same numerical result of 16 for the first limit. There is a mix of strategies being discussed, including algebraic manipulation and the use of known limit properties, but no consensus on a single method has been reached.
Some participants mention constraints related to their current coursework, specifically that they are not yet covering derivatives, which impacts their approach to the problem.
vgower
Limits
I'm doing some online practice work... and I can't find out how to get the following two limits... I know they are not undefined.
The limit as x approaches 0 of sin^2(4x) / xtan(x) .. I tried to flip it... but I couldn't get it that way either.
The limit as x approaches 0 of (x + tan(4x)) / sin(9x)
Any help would be appreciated.
We're not doing derivitaves yet.. so it wouldn't make sense.. but I could try.
Doesn't work.
I am getting 16 as my answer. I first broke [tex]\sin(4x)^2[/tex] into [tex](2\sin(2x)*\cos(2x))^2[/tex] and then I further broke this down to [tex]16\sin(x)^2\cos(x)^2(\cos(x)^2-\sin(x)^2)^2[/tex]. Then I didived it by x*tan(x) from which I got:
[tex]16*\frac{\sin(x)}{x}\cos(x)^3(\cos(x)^2-\sin(x)^2)[/tex]
Then ... here is the muddy part ... I assumed that the limit of the products is the product of the limits. Then, since the limit of sinx(x)/x is 1, you end up with 16 as your answer after you evalute the rest of the limit at x=0.
Then find a reason why you can assume that. It's not hard.
Incidentally, if you know (sin x)/x --> 1 as x --> 0, there's a much easier way to deal with sin (4x)...
i also got 16 for the first one using l'hospital's rule (although I had to go to second derivatives) but I just expanded sin^2(4x) as [1-cos(8x)]/2 and did l'hospital's rule twice (making sure I kept my fractions separate)
You're all making these way too hard. Think about it -- what is the intuitive meaning of:
[tex] \lim_{x \rightarrow 0} \frac{\sin x}{x}[/tex]
? Does it tell you anything interesting geometrically or algebraically?
Highlight if you need to see the answer: (it tells you that, when x is small, sin x looks and acts very much like x[/color])
So what does that tell you about these limits?
The simplest method would be L'Hopital's rule. Have you tried that? If you don't want to do that, you might separate it as
[tex]4\frac{sin(4x)}{4x}\frac{sin(4x)}{tan(x)}[/tex]
You should know the limit of [itex]4\frac{sin(4x)}{4x}[/itex] and you should be able to use the trig identity sin(4x)= 2sin(2x)cos(2x) to reduce
[tex]\frac{sin(4x)}{tan(x)}[/tex]
This same question was asked under "homework". I am going to combine the two threads.
You shouldn't need the trig identity. :wink: The only facts you need are the elementary limit properties, and that the limits of (sin x)/x and (tan x)/x are both 1, as x goes to zero.
  • · Replies 26 ·
  • · Replies 40 ·
