Need help with lots of different types of problems
  • Thread starter Thread starter RubyRed
The discussion revolves around various algebraic problems, including volume calculations and quadratic equations. The original poster seeks assistance with a problem involving the dimensions of a chocolate bar and another regarding the conditions for a quadratic equation to have a repeated solution.
  • Mixed
  • Participants explore the volume reduction of a chocolate bar, questioning how to maintain the relationship between length and width while reducing dimensions. They also discuss the conditions for a quadratic equation to have a repeated solution, with some participants attempting to clarify the implications of this condition.
There is an ongoing exploration of the problems, with participants providing hints and guidance without reaching a consensus. Some participants have made progress on the chocolate bar problem and are attempting to solve the quadratic equation, while others express confusion about specific steps and concepts.
Participants note the constraints of the homework context, including the requirement to reduce the volume by a specific percentage and the conditions for the quadratic equation. There is also mention of the need for clarity on mathematical definitions and procedures.
RubyRed
I already posted a thread about a "physics" (although I am actually in basic college algebra) but I have a few more that I need help with.
1) A jumbo chocolate bar with a rectangular shape measures 12 cm in length, 7cm in width and 3 cm in thickness. Due to escalating costs of cocoa, management decides to reduce the volume of the bar by 20%. To accomplish this reduction, management decides that the new bar should have the same 3 cm thickness but the length and width of each should be reduced an equal number of centimeters. What should the dimensions of the new candy bar be?
~Now I know that the formula for volume is lwh. So I took the original measurements 12 x 7 x 3 and got 252. I reduced that by 20% which would be 252-50.4= 201.6 to get the new volume of the reduced bar. Now I know that the thickness is going to stay the same so I think the new equation would be 201.6=lw x 3. I need to make sure that the length and width get reduced the same amount so I have to make sure that they stay 5 cm apart (if original l=12 and w=7 12-7=5cm) so I made the equation say 201.6= w+5 x w x 3 (x's are multiplication symbols by the way) but now what do I do..do I subtract 5 from both sides and make the w's w^2 and then divide both sides by 3 and square root the answer to get w? And then once I know that I can find l? I don't know what to do from here!
2)Find k such that the equation x^2 - kx +4 =0
Ok so I subtacted 4 from each side to get x^2 - kx= -4 Now I am horrible at these so I am probably way off but then I divded both sides by x...so that I had x-k = -4 over x (I don't know how to type fractions, sorry!) but I had no idea what to do from there...I am supposed to only keep a constant on the right correct? So moving x over seemed wrong to me, but with only one given number in an equation I don't know what to do.
I guess that is it for now, I have more but maybe I can do them once I know how to do these ones. Thanks guys!
#1 has me a bit stumped at the moment :s
but #2 you did good so far getting [tex]x-k=\frac{-4}{x}[/tex] and now you just to have to continue solving for k by having k by itself on one side of the equation
I just realized that I didn't type the entire problem for number 2...it should say "find k such that the equation x^2-kx+4=0 has a repeated real solution." So I should move x over in which case Iwould have -k=-4-x...which would make k=4+x and that is as far as I can go right? But what about the repeated real solution part that I am supposed to find? Kinda confusing to me
uh repeated real solution? never heard of that sorry. Does your textbook have any mention of repeated real solution?
but in the solution [tex]k=4+x[/tex] you droped the /x on the 4
In my textbook all it says is "When the left side factors into two linear equations with the same solution, the quadratic equation is said to have a repeated solution." It doesn't say the word real in the definition but I am assuming they are referring to a repeated solution with real numbers...still a bit confusing to me. ohh so the solution should be k= 4/x + x , can you add that together and make it k=4/2x which would just = 2x right? so is k=2x the answer?
ok finally i solved #1 :s so i can help you out with it:
so you know from the question that 12 and 7 will be lowered by the same amount right? so one way to solve it is to create 3 equations to solve this problem:
the original
l*w*3=201.6
[tex]l=12-x[/tex]
[tex]w=7-x[/tex]
so ill let you have a go at it and see if you can solve it
ok can you give me the next step to get started on because I am stumped...
wait! ok so 201.6 = (12-x)(7-x)(3) is that the right direction?
ooo i get that now, what they mean is like in the quadratic equation a (real) repeated solution would be when the determinant [tex]b^2-4ac=0[/tex] which would give a repeated solution, what they also want is this to be a real solution, no negative square roots.
so using the original equation you just plug in for b, a, c and solve for k
just in case you forgot the quadratic equation is in form [tex]ax^2+bx+c=0[/tex]
so should I foil the first 2 and then multiply by 3? ugh but then how do I separate what is l and what is w?
yes that's the right direction, but i recommend before plugging in the value's for l and w to move the 3 to the right side to make things a bit easier, and then do foil and solve for x
so after foiling 201.6= 252-57x+3x^2
that doesn't seem right to me... ok I am confused again
try dividing both sides by 3, and then foiling, then you'll have a quadratic equation which you can solve using the quadratic formula
[tex]x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}[/tex]
or you could do that now by moving the 201.6 over to the right side which would give you
[tex]3x^2-57x-50.4=0[/tex]
so if I divide both sides by 3 I have 67.2 = (12-x)(7-x)/3 is that right so far?
but how do I foil it if it is all over 3?? or when I divide by 3 does it just cancel out the (3) and not affect the others. Should it be 67.2=(12-x)(7-x)
no, if you divided by 3 you'd just have 67.2=(12-x)(7-x)
ok I thought you had to divide every single thing by 3...my bad(jeepers it has been so long since I have done this!), ok so now I have 67.2=84-19x+x^2 so now I can plug it into the equation you showed me?
the quadratic formula I mean
well if you had it lw3 then it would be 3l*3w, so dividing by 3 would just leave lw or (12-x)(7-x)
edit: sorry didnt see your last posts
kz you got everything right so far, now just move the 67.2 over to the right side so its all =0 and plug a/b/c intot he quadratic formula to solve for x
ok I got x=12 or x=7 but those were the original 2 numbers. lol...how did i get that? I will try to show what I did. I foiled and got 67.2= 84-19x+x^2 I plugged it in and got x= -(-19) +- square root of 19^2-4(1)(84) over 2(1) (you might want to write that out to visualize it) so then I got it down to x=19+- square root of 361-336 over 2. Which = x=19 =- square root of 25 over 2, which is then x=19 +- 5 over 2. So then I did x=19-5 over 2 which is x=14 over 2 which is x=7. Then 19+5 over 2 which is x=24 over 2 which is 12...but those can't be right becuse then it would be the SAME EXACT as before I reduced it by 20%...how did that happen?
you forgot to move 67.2 over to the right side, the equation should be [tex]x^2-19x+16.8=0[/tex] now if you solve for x and then plug that in for the 12-x, 7-x you should get the new length/width for the candy bars
p.s. this is a thread that shows how to use the LaTeX typesetting which is what shows the equations in the way you would see them in a book or written out properly
https://www.physicsforums.com/showthread.php?t=8997
it's not hard to learn it and it might be useful from time to time in these forums
oh yeah! I see my mistake now, ok let me do this real quick...hey thanks for that URL for that...that will make it much easier!
so now I need to find the square root of 146.9...but that number is soooo long...do I just round it to like the hundreth or something?
how did you get 146.9?
and yes you would have to round the answer off
ok I took 0=16.8-19x+x^2 (sorry I am not using that page you showed me yet, I haven't had time to look at it) and I plugged it into the quadratic formula sooo( I probably won't do exactly step for step and SR means square root)
x= 19 +- SR -19^2 - 4(1)(16.8) over 2
x= 19 +- SR 361 - 67.2 over 2
x= 19 +- SR 293.8 over 2
and then I divided SR 293.8 by 2 and got SR 146.9. Should I have gotten the SR of 293.8 before dividing by 2 and even so that number is17. something and it is an extremely long number...which would be harder to divide by 2.
yes, but also its (19+-SR 293.8) over 2, i think if you're using windows there's a calculator on the start>programs>accessories that has the square root function, or you could just use a calculator to find it
right so when I put SR 293.8 over 2 to get rid of the 2 I divide and it ends up being 146.9...which is how I got that number that you asked me how I got it. That's right isn't it? And then I find the SR of that which is 12.12023102090055 and so on... so say I round it to 12.12 then I put 19-12.12 = 6.88 or 19+12.12 =31.12
then plug it into the l= 12-x and w=7-x I have l= 5.12 or -43.12 (which it couldn't be negative) so it must be the 5.12. And w = .12 (which seems awfully small) or w= -24.12 (which once again it is negative)...what did you get for answers?
no you don't divide by 2 yet
uh here's the equation with LaTeX typesetting
[tex]x=\frac{19\pm\sqrt{293.8}}{2}[/tex]
if you have a calculator just type in ((sqrt 293.8) + 19) /2 for 1 of the answers, and for the second it would be (19 - (sqrt 293.8))/2, and you will notice only 1 of the answers will give you a real solution when you plug it into the (12-x) and (7-x)
ok so for the first one I got 18.07029 so on and so on and for the second one I got
0.929702 so on and so on...is that right?
all I have is the windows calculator so I don't know if it did it right.
  • · Replies 32 ·
