| Thread Closed |
Point source of light beneath water. |
Share Thread | Thread Tools |
| Sep7-06, 03:34 PM | #1 |
A point source of light is 245.0 cm below the surface of a body of water. Find the diameter of the circle at the surface through which light emerges from the water.
Can someone give me a push start as to how to approach this problem? I can't figure it out for the life of me. I know that v=c/n, and using 1.33 at the index of refraction of water, I can find the velocity of the light as it reaches the surface is 2.3E8m/s. The point source will emit light isotropically in all directions, and I have the distance to the surface... but for the life of me I can't find how to relate this to the diameter of the circle it will leave on the surface. |
| Sep7-06, 04:24 PM | #2 |
Mentor
Does your text cover "total internal reflection"? That's the reason why light that is angled way out to the side won't make it out of the water....
| Sep7-06, 04:49 PM | #3 |
Thank You. Im such a bonehead sometimes.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Point source of light beneath water.
| Why triple point of water is higher than freezing point | Classical Physics | 7 | ||
| Angles of Nodal Lines (Two point light source) | Introductory Physics Homework | 1 | ||
| luminous intensity due to an isotropic point source of light | Advanced Physics Homework | 1 | ||
| Does light from a point source spread out? | Introductory Physics Homework | 7 | ||
| Basic question regarding triple point of water and physical properties of water | Introductory Physics Homework | 9 | ||
