Calculate Distance of 2.75 μC Charge from Origin | Physics
  • Thread starter Thread starter FlipStyle1308
    Charge Origin
The discussion focuses on calculating the distance from the origin at which a 2.75 μC charge attains half the speed it will have at infinity. The initial speed of the second charge, also 2.75 μC, when released from rest is 8.6838 m/s. The correct approach involves using the potential energy and kinetic energy equations, specifically PEi = KEf + kq1q2/r and v = √(2Δ(-PE)/m). The final solution requires solving for r using the derived relationship, confirming that the initial calculations were incorrect.
  • Understanding of electrostatics, specifically Coulomb's law.
  • Familiarity with potential energy (PE) and kinetic energy (KE) equations.
  • Knowledge of basic algebra for rearranging equations.
  • Ability to apply the Pythagorean theorem in two-dimensional problems.
  • Study the derivation of energy conservation in electrostatic systems.
  • Learn how to apply the Pythagorean theorem in electrostatic contexts.
  • Explore the implications of charge interactions in different configurations.
  • Investigate the effects of varying mass and charge on speed calculations in electrostatics.
Students and professionals in physics, particularly those focusing on electrostatics, as well as educators seeking to enhance their understanding of energy conservation principles in electric fields.
FlipStyle1308
A charge of 2.75 μC is held fixed at the origin. A second charge of 2.75 μC is released from rest at the position (1.15 m, 0.350 m). If the mass of the second charge is 1.50 g, and its speed when it moves infinitely far from the origin is 8.6838 m/s, at what distance from the origin does the 2.75 μC charge attain half the speed it will have at infinity?
I calculated the 8.6838 m/s by using PEi = KEf +. kq1q2/r = (mv^2)/2 => v = sqaure root of (2kq1q2/mr). I tried rearranging the equation to solve for r = 2kq1q2/mv^2, and got an answer of 4.8084 m, however, my answer is not correct. I used k = 8.99 x 10^9 Nm^2/C^2, q1 = 2.75 x 10^-6 C, q2 = 2.75 x 10^-6 C, m = 0.0015 kg, and r (for the first problem) = 1.2021 m (using Pythagorean theorem). Any ideas of where I went wrong?
You have to solve for [itex]v = .5v_\infty[/itex]
Since:
[tex]v = \sqrt{2\Delta (-PE)/m} = \sqrt{\frac{2kq^2}{m}\left(\frac{1}{r_0} - \frac{1}{r}\right)}[/tex]
and
[tex]v_\infty = \sqrt{\frac{2kq^2}{m}\frac{1}{r_0}}[/tex]
the condition [itex]v = .5v_\infty[/itex] is just:
[tex]\sqrt{\frac{2kq^2}{m}\left(\frac{1}{r_0} - \frac{1}{r}\right)} = \frac{1}{2}\sqrt{\frac{2kq^2}{m}\frac{1}{r_0}}[/tex]
solve that for r.
AM
PS you will note that you do not have to use k, q, m or calculate that speed at infinite separation.
Okay, I figured it out, thank you!
9K
12K
13K
