Calculating Frequency from Sound Samples
  • Thread starter Thread starter Traveller
    Frequency
The discussion revolves around calculating frequency from sound samples using a computer program. The original poster is analyzing sound waves captured from a sound card and is seeking guidance on how to derive frequency from these samples, particularly in the context of using Fourier transforms.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to understand how to calculate frequency from sound samples and expresses uncertainty about the formulas they know. Some participants suggest using the Fourier transform and discuss the importance of window functions in the analysis. There are questions about the accuracy of the frequency readings obtained from the FFT graph and whether the digitization or FFT process may be introducing errors.
Participants are exploring various aspects of the problem, including the original poster's use of FFT and the discrepancies in frequency readings. Guidance has been offered regarding checking the period in the time function data and the effects of different window functions. The discussion is ongoing with no explicit consensus reached yet.
The original poster indicates a lack of strong physics background, which may affect their understanding of the concepts discussed. There is also mention of specific frequencies input from a signal generator and the corresponding outputs observed, suggesting a potential issue with the analysis process.
Traveller
Hi everybody ...
I have to write a computer program about analysizing the sound wave ... and I don't know much about it ...
Now I'm taking the signals from the sound card and save them in an array ...
So I got a set of samples ... using those samples I can make a picture and it will show a kind of wave depending on the input ...
Now my problem lies here ... If I want to calculate the frequency from that set of samples ... is it possible ...?
If there is any formula ... will you do a favor for me by letting me know ...?
f=(1/T) or f=(c/lambda) or f=(v/lambda) ... I only know those 3 and I don't know how to use them for a set of samples ...
Maybe my question is not showing a meaning ... because I don't know physics very well ... but I have to write the program and so I need someone to help me ... ;-)
Thanks in advance ...
Miles to go before I sleep
Look up the keyword Fourier transform
For a continuous sine wave, you get two zero crossings per period. The frequency, as you wrote, is the inverse of this period: f = 1/T. You know your sample rate per point, so the number of samples that it takes to get two zero crossings tells you the period T.
If you have a mix of signals, then as nbo10 says, you will need to do some analysis like a Fourier transform on the signals. You will first need to apply a "window" function to your data, since the Fourier transform applies to inifinite-time functions, and you have a finite-time sample with square edges. The windowing function softens the edges, basically. Also, you will probably use a form of the FT called the Fast Fourier Transform (FFT). You could start at wikipedia:
http://en.wikipedia.org/wiki/Fast_fourier_transform
Thanks
Thank you both for your reply ...
Yes I used FFT for drawing a graph in Frequency Domain ...
Although I did it ... I didn't understand it very well ;-) ...
But I surely got that graph ...
Then I find out the highest y of that graph and take the corresponding x as the average frequency ... but it is exactly shows the frequency that I input from the signal generator ... I mean when I input with frequency 10 ... it shows 11 ... then 20 ... it shows 22 ... then 150 ... it shows 142 ...
So I don't want to extract from the graph ...
I don't know what to do now ...
While calculating fft series ... can I extract the frequency from that series ...?
With all my thanks and regards ...
Miles to go before I sleep ...
I typed wrong ... let me correct it ...
Then I find out the highest y of that graph and take the corresponding x as the average frequency ... but it is not exactly showing the frequency that I input from the signal generator ... I mean when I input with frequency 10 ... it shows 11 ... then 20 ... it shows 22 ... then 150 ... it shows 142 ...
So I don't want to extract the frequency from the graph ...
When you put in a sine wave and graph the time function, do you see the correct period in the v(t) data? Check that first to determine whether the error is in the digitization step, or the FFT step. What window function are you using? How many cycles of the sine wave are in the data? If you artificially cut the data set so that the waveform starts very close to zero and also ends very close to zero, do you get a better answer?
Yes ...
Your advice is very good ...
I should test them separately ...
Let me come back later ...
With thanks & regards ...
  • · Replies 19 ·
