Find Force F(v) of Boat Drag Force: Barger's Classical Mechanics
The problem involves analyzing the drag force acting on a boat as its velocity decreases over time, as described by a specific mathematical relationship. The context is rooted in classical mechanics, particularly focusing on forces and motion.
  • Participants explore the relationship between the drag force and the decreasing velocity, questioning the justification for the negative sign in the force equation. They discuss the implications of the velocity's direction and its relationship to the force applied.
The discussion is active, with participants providing insights into the nature of the drag force and its direction relative to velocity. There is an exploration of different interpretations of the velocity equation and its implications for the sign of the force.
Participants note the significance of the time variable in the velocity equation and how it affects the interpretation of the force's direction. There is an emphasis on the assumptions regarding the signs of velocity and force in the context of drag.
t!m
I have a question about a physics problem, this comes from Barger's Classical Mechanics: A boat is slowed by a drag force, F(v) and its velocity decreases according to the formula [tex]v=c^2(t-t_{1})^2[/tex] where c is a constant and [tex]t_{1}[/tex] is the time at which it stops. Find the force F(v) as a function of v.
So I figured [tex]F=ma=mdv/dt=md/dt(c^2(t-t_1)^2)[/tex]. After differentiation, I get [tex]F=2mc\sqrt{v}[/tex]. The solution in the back has a negative sign, and I'm wondering what justifies the negative. I'm assuming it has somethign to do with the fact that it is a drag force and the velocity is decreasing, but it's not entirely clear. Thanks in advance.
Because in your original problem the velocity is decreasing, thus the first derivative of velocity
must be negative right?
For the force to slow down the boat, it must be applied in the inverse sense of the velocity. If the velocity is positive, the force must be negative.
It's obvious in the given equation...
If you were to look at the given equation the (t-t1)^2 part, you would notice that as time increases from 0, the velocity becomes less negative until eventually reaching 0 when t=t1. This must mean that velocity is directed in the negative direction and force is in the positive direction.
If however you were to take it as (t1 - t)^2 , which wouldn't really change the velocity equation, the directions are reversed and force is in the negative direction.
Hope this helped.
The velocity is always positive, the acceleration negative. As SGT (and jaredkipe) stated, the force must be negative.
When taking the square root of v, there are two answers: one plus, one minus. You have to choose the minus answer, since that's the one that fits this situation.
Just to be clear:
[tex]c (t - t_1) = -\sqrt{v}[/tex]
[tex]c (t - t_1) \ne +\sqrt{v}[/tex]
  • · Replies 24 ·
12K
