| Thread Closed |
newton's laws |
Share Thread | Thread Tools |
| Sep10-06, 03:18 PM | #1 |
newton's laws
"a person drives their 1452 kg car along a straight road at a constant velocity of 30 m/s east. their brakes suddenly give out. they put the car in neutral and let is coast for 25 seconds. the air drag decelerates the car to a velocity of 25 m/s east. (assume a frictionless surface)."
b) assume the average acceleration while the car is decelerating so it's just (25 m/s - 30 m/s)/25 s = -0.2 m/s^2? c) determine the average force of air against the car f = ma = (1452 kg)(-0.2) = 290.4 N d) after coasting for 25s. they pull their car handbrake to slow the car to a stop. this take 3 seconds. what is the force applied by the handbrake? assume that the force exerted by the air remains constant and is equal to the forced determined in part (c). so i assume i find acceleration by (0 - 25)/time but for the time is it (25s-3s) or (3s - 25s)? and then i just the acceleration times the mass of car = handbrake force? any help will be appreciated! ~Amy |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Sep10-06, 03:25 PM | #2 |
You have to consider only the last 3 seconds during which the car is moving.
acceleration times the mass of car = handbrake force? That's right. |
| Sep11-06, 04:08 PM | #3 |
thanks neutrino.
for d) i got -8.33 m/s^2 for the acceleration abd -12100N for the force of the handbrake. in e) it asks "what is the total displacement from the time the brakes give out to the time the car stops" so for this i used the formula: d = (0.5)at^2 + v1t = (o.5)(-8.33)(3^2) + (25m/s)(25s) = 587.52m can someone tell me if this is accurate? ~Amy |
| Sep11-06, 05:00 PM | #4 |
newton's laws
another question i want to check:
"peter and john are playing tug of war on a frictionless surface. peter weighs 539N and john weights 393N. john accelerates towards peter at 3 m/s^2. " a) what is the magnitude of the force that peter exerts on john? 539N times 3 m/s^2 = 1617N? any help is appreciated! ~Amy |
| Sep12-06, 11:12 AM | #5 |
for this one:
"peter and john are playing tug of war on a frictionless surface. peter weighs 539N and john weights 393N. john accelerates towards peter at 3 m/s^2. " a) what is the magnitude of the force that peter exerts on john? first i calculated john and peters mass by diving this newton weight by the force of gravity (9.8 m/s^2). so peter is 55 kg, and john is 40 kg. then for part a) i took peters mass (55 kg) times (-3 m/s^2) = -165N. not sure if this is accurate. help? ~Amy |
| Sep12-06, 12:07 PM | #6 |
Mentor
(1) air drag only (coasting) (2) air drag + hand brake |
| Sep12-06, 12:13 PM | #7 |
Mentor
| Sep12-06, 12:30 PM | #8 |
thanks!so it'd be 120N what then how would i find the magnitude of the force that john exerts on peter? would it be -120N? thank you ~Amy |
| Sep12-06, 12:36 PM | #9 |
Mentor
| Sep12-06, 01:40 PM | #10 |
= 687.5 m for (2) i got (0.5)(-8.33 m/s^2)(3^2) = -37.485 so 687.5 + - 37.485 = 650.02 m more on the john/peter saga.. and to find the c^2 it's (45^2) + (25^2) = 51.48 N and to find the tan angle is 26 degree north/west. so to find sarah's acceleration i go 51.48N/30 kg? ~Amy |
| Sep12-06, 02:07 PM | #11 |
Mentor
Use the full equation: [tex]d = v_0 t + (1/2) a t^2[/tex] (don't forget the initial velocity!) You can also use the exact same equation you used for segment (1). |
| Sep12-06, 02:19 PM | #12 |
ok so (25m/s)(3s) + (0.5)(-8.333)(3^2) = 37.515 650.02+37.515 = 687.54 m thanks for the help! ~Amy |
| Sep12-06, 02:27 PM | #13 |
Mentor
| Sep12-06, 02:47 PM | #14 |
![]() ~Amy |
| Thread Closed |
| Thread Tools | |
Similar Threads for: newton's laws
| More of newton's laws | Introductory Physics Homework | 9 | ||
| Newton's Laws | Introductory Physics Homework | 19 | ||
| Newton's Laws | Introductory Physics Homework | 4 | ||
| Newton's Laws - I need help | Introductory Physics Homework | 17 | ||
| newton's laws | Introductory Physics Homework | 2 | ||
