Solution of 1D Schrodinger using discretized hamiltonian
The discussion revolves around solving the 1D Schrödinger equation using a discretized Hamiltonian approach, specifically for calculating Franck Condon factors related to absorption and emission spectra. Participants explore issues encountered while implementing this method, including the behavior of eigenvalues and eigenvectors derived from the discretization process.
  • One participant describes their approach to solving the 1D Schrödinger equation using finite difference methods and expresses difficulties with the resulting eigenvalues and eigenvectors, noting oscillation behavior in the wavefunctions.
  • Another participant reports a similar issue while using Python's numpy.linalg package for diagonalization, suggesting that the problem persists even with a 5-point stencil for the second derivative.
  • A question is raised regarding the specific form of the potential being used, with one participant confirming they are testing with a square well potential (V(x)=0).
  • Concerns are expressed about the implementation of the linear algebra routines in Python, with a mention of successful results using Fortran's LAPACK function dstevx.
  • One participant suggests that setting "walls" around the region of interest with a high potential could prevent wavefunction leakage, emphasizing the importance of placing these walls at energies higher than the eigenvalues of interest.
Participants do not reach a consensus on the cause of the issues with eigenvalues and eigenvectors. Multiple competing views on the effectiveness of different computational approaches and potential implementations remain unresolved.
Participants acknowledge potential limitations related to the choice of numerical methods and the handling of boundary conditions, but do not resolve these issues within the discussion.
beady
Hi all,
I'm trying to solve the 1D Schrödinger equation for an arbritary potential, to calculate Franck Condon factors for absorption and emmision spectra. I can do this using iterative techniques (e.g. the Numerov method), but I can't seem to get it to work by discretrizing the hamiltonian, and then finding the eigen vectors/values. Here's what I'm doing, hopefully someone can help.
initial hamiltonian : [tex]H=\frac{1}{2 I}\frac{d^2}{dx^2} + W(x)[/tex]
Split the space up into n points.
use the standard finite difference relations for a second derivative leads to:
[tex]\frac{1}{2I}\frac{v_{i-1}-2v_{i}+v_{i+1}}{\delta^2}+W_i v_i = E v_i[/tex]
and the relevant forward and backward differences for the endpoints.
I then set up a matrix for the above linear equations, and then just solve the system using either Matlab or Mathematica eigenvalue and eigenvector routines.
The problem is that the resulting eigenvalues ( energies ) are completely wrong, and the wavefunctions ( individual eigenvectors ) are weird. It seems that the eigenvectors oscillate around around y=0. It's difficult to explain, but if the desired wavefunction is phi, then at even grid points (n=2,4,6...) , I get the correct phi(x) value, but for odd grid points (n=1,3,5,7...), I get -phi(x). This is easily corrected, but why is it happening?
Is it possible to calculate the wavefunction using this method? I may have made a coding error, but I'm interested to know if the method above should work, and if not, why not.
Thanks in advance
Hi,
did you ever have any luck solving this? I have the same problem using python (using the numpy.linalg package to perform the diagonalization). What's more it seems to persist even for a 5 point stencil for the second derivative.
What is the form of the potential for which you are getting the bad results.
Hi, actually I am just using a square well potential at the moment (for testing) - ie. V(x)=0. In my case, I suspect it is something to do with using the python linalg.eigh implementation, as it seems to work in Fortran with a call to the lapack function dstevx (which diagonalizes a tridiagonal matrix).
Ah. Well we use NumPy and SciPy around here so if there is a problem with it's linear algebra package we would certainly want to know about it. Please keep me informed. Thanks.
Solving the 1D SE by calculatint eigenvectors/eigenvalues is fairly easy. The only "tricky" part is setting up the matrix (and relazing that it is is tri-diagonal).
However, there is one thing you need to watch out for: it is a good idea to put "walls" around the region of interest (i.e. set V(x)=a very large number) or otherwise the wavefunctions might "leak out" in non-physical way with some solvers (in principle you should also be able to simply use a very "deep" well but that is not very efficient).
You obviously have to make sure that you put the "walls" at an energy much higher than the eigenenergies you are interested in, or otherwise they will affect the result.
