Thread Closed
Seeing around corners
Share Thread Thread Tools
Sep11-06, 04:17 PM   #1
Take an object with well defined features, illuminated by a full spectrum source and located around a sharp, 90 degree vertical corner. How well can an observer hidden behind the corner from the object and at the same height reconstruct its image from the diffracted light?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Sep12-06, 08:22 AM   #2
Recognitions:
Homework Helper Homework Help
As well as I can see you now.
Sep12-06, 10:03 AM   #3
Recognitions:
Gold Membership Gold Member
To some extent, it might depend upon ambient conditions. Loren seems to be alluding to the mirage effect, which is very real. I've never heard of it working around a 90 degree bend, though.
Sep12-06, 10:50 AM   #4
Recognitions:
I would say it's entirely dependant on the mechanism used to collect the data (the diffused light). For example, if the observer used a mirror, he could tell a lot about the object. If he used no instrument, he could tell nothing at all. If the experiment took place in a vacuum, he could tell nothing at all, because light doesn't diffuse in a vacuum.
In a perfectly dust-free "clean room", almost no data. In a smoke-filled bar, color and size perhaps (if the source of illumination were bright enough).
Sep12-06, 05:03 PM   #5
Folks,
Pardon, I was referring to diffraction than diffusion. Would that change your answers? Consider the phenomenon in vacuo.
Sep12-06, 06:41 PM   #6
Recognitions:
If you are observing right on the wall, you would get no information whatsoever. This is because light takes a finite amount of time (and distance) for the diffraction angle to evolve from 0 to whatever the far-field diffraction angle may be.
Claude.
Sep12-06, 10:21 PM   #7
In one-slit diffraction, all interference fringes (with the information they represent) but one are not along a straight (classical) path from the light source, through the slit and to the screen. The same argument holds for a object, corner and observer.
All that remains is for the observer to reconstruct the information about the object from the fringes, but can it be done in practice? (Using some kind of Fourier transform?)
Sep13-06, 09:50 AM   #8
Remember that this one-slit example is illuminated by a full-spectrum source. The interference displayed on the screen arises from those wavelengths interacting with the geometry of the slit itself. This experiment, as explained above, is analogous to the "corner" situation.
Thread Closed
Thread Tools
Similar Threads for: Seeing around corners
Thread Forum Replies
Why Charge Accumulates at Edges/Corners? Classical Physics 3
Practical Problem: mitering corners Calculus 0
Banking corners Problem regarding assignment Introductory Physics Homework 9
Stress singularity at corners Mechanical Engineering 5
How to shoot around corners Computing & Technology 3
