Calculating Average Lifetime of Particles at Rest
The discussion centers on calculating the average lifetime of elementary particles at rest, given their measured lifetime in motion. The formula used is tm = ts / [sqrt(1 - v^2/c^2)], where tm is the moving lifetime, ts is the stationary lifetime, v is the particle's speed (2.0 x 10^6 m/s), and c is the speed of light. The correct calculation yields a stationary lifetime (ts) of 1.2 x 10^-8 s. The user initially miscalculated due to an incorrect speed value.
  • Understanding of special relativity concepts
  • Familiarity with the formula for time dilation
  • Knowledge of the speed of light (c)
  • Basic algebra skills for solving equations
  • Study the principles of time dilation in special relativity
  • Learn how to apply the Lorentz transformation equations
  • Explore examples of particle physics involving relativistic speeds
  • Investigate the implications of relativistic effects on particle lifetimes
Physics students, educators, and anyone interested in the principles of special relativity and particle physics calculations.
msimard8
Heres the question before I say anything else
A beam of unknown elementary particles travels at a speed of 2.0 x 10^6 m/s. Their average lifetime in th ebeam is measrured to be 1.6 x 10^-8 s. Caclulate their average lifetime when at rest.
hmm I have no examples to go by. I figure I will have to use the formula
tm = ts/[sqrt(1-v^2/c^2)]
where tm is the time it takes when the object is moving (for example when viewing from Earth and ts is the stationary time, v is speed of the object and c is speed of light)
I tried to do this by plugging in the numbers as
ts=?
v=2.0x10^8 m/s
tm=1.6x10^-8
I didn't get the right answer of 1.2 x 10^-8 s so I am assuming I am wrong.
How do I do this correctly.
Well you are using the right formula and I get the right answer when I plug the numbers in. If you tell us what answer you get perhaps we can tell you what you're doing wrong.
EDIT: just noticed you cited
ts=?
v=2.0x10^8 m/s
as what you've input.
That could be the problem.
  • · Replies 30 ·
