Jump Time: Analyzing a Basketball Player's Vertical Leap
The discussion revolves around a basketball player's vertical leap, specifically analyzing the time spent in the top and bottom segments of the jump. The problem involves concepts from kinematics and motion under gravity.
  • Participants discuss the time spent in the top 15 cm versus the bottom 15 cm of the jump, with some suggesting that the player slows down and reverses direction at the peak. Questions arise regarding the acceleration during the jump and its implications on velocity.
Participants are exploring various aspects of the problem, including the effects of acceleration and gravity on the player's motion. Some guidance has been offered regarding the equations of motion, but there is no explicit consensus on the next steps or solutions.
There is a recognition that the acceleration is not constant throughout the jump, and participants are questioning the nature of acceleration versus velocity. The problem is framed within the constraints of a homework assignment, which may limit the information available for discussion.
physics newb
Here with a question, and I'm a bit crunched for time. I'm also here to learn, too.
A basketball player, standing near the basket to grab a rebound, jumps 76.0 cm vertically. How much total time does the player spend (a) in the top 15.0 cm of this jump and (b) in the bottom 15.0 cm? Does this help explain why such players seem to hang in the air at the tops of their jumps?
Thanks in advanced!
soooo... do you have nay thoughts on what to do??
Not exactly, I guess that's why I'm here. I assume the player will be in his top 15.0 cm for a longer time than the bottom 15.0 cm, since the player has to slow down when he's in the air, reverse his direction, and speed up again (downward).
can you find the time he will be spending up there, though
can you find his velocity while he is going upward as he enters the upper 15cm?? can you find the velocity when he is coming down thru the 15 cm again??
Hint: what is the acceleration?
I'm not sure that I can answers those. The acceleration is not constant though I know, seeing as it changes direction at some point. Other than that, I'm just about clueless.
who is causing the acceleration?? and which way does it point?
make sure you are not confusing 'acceleration' with 'velocity'
still confused?.. what does acceleration do then??
The acceleration would be caused by the initial jump upwards? And then gravity pulling him back down?
Acceleration is increasing speed, right?
Acctually acceleration is CHANGING velocity.
OK then, but I'm still not sure what to do next.
With constant acceleration -9.8 m/s2, initial velocity v0, height at time t seconds is x(t)= v0t- 4.9t2 and velocity at time t seconds it v(t)= v0- 4.9t. He will keep going up as long as v(t) is positive, then come back down. That means that he will get to his highest point when v(t)= 0 v0- 4.9t or when t= v0/4.9. Put that into the equation for his height then:
x(t)= v0(v0/4.9)- 4.9(v0/4.9)2= 76 cm and you can solve for v0.
Once you know that, you can find the time it takes him to go from x= 0 to x= 15 (the low 15 cm) and the time it takes him to go from 76-15= 61 cm to 76 cm (the high 15 cm). O course, the time he stays in the "high 15 cm" region will be twice that- up to 76 cm then down to 61 cm again.
  • · Replies 20 ·
