Acceleration due to gravity
The discussion revolves around calculating the acceleration due to gravity for a stone thrown upward from the ground at a velocity of 14 m/s, which returns to the ground in 9 seconds. The context specifies that this scenario does not take place on Earth.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between initial velocity, time of flight, and acceleration due to gravity. Some discuss the conservation of energy principles, while others question the calculations and interpretations of velocity and acceleration.
There are multiple interpretations of the acceleration value, with some participants suggesting different calculations based on the time taken for the stone's ascent and descent. Guidance is offered regarding the conservation of energy, but no consensus on the final value of acceleration has been reached.
Participants note the specific conditions of the problem, including the absence of air resistance and the unique context of the stone's motion not being on Earth. There is also a discussion about the implications of using "velocity" versus "speed" in the context of the problem.
ACLerok
a 2.50-kg stone thrown upward from the ground at 14. m/s returns to the ground in 9. s
my question is: is it possible to find the acceleration due to gravity? (keep in mind this is not taken from earth.)
Sure. Assuming that gravity is the only thing accelerating the object (i.e., there's no air resistance or anything), you can use the following equation:
[tex]a = \frac{\Delta v}{\Delta t}[/tex]
Here, vo = +14 m/s (the velocity it was thrown at, Δt = 9 s, the elapsed time, and v = -14 m/s. That initial kinetic energy was traded off for gravitational potential energy on the way up, and then given back as kinetic energy on the way down, so it ended up with the same magnitude velocity (remember that we said no energy was lost to air resistance or anything like that).
Yes. The stone will have the same velocity when it hits the ground as it did when it originally left. Conservation of energy. As the stone reaches maximum height, all of its kinetic energy will have been converted to gravitational potential energy. As the stone falls, this potential energy will be converted back to kinetic energy.
Knowing the original velocity and Time, acceleration is easy to calculate.
lol, you beat me to it James!
so is the acceleration 28/9 m/s^2?
I missed something here. The original question stated: a 2.50-kg stone thrown upward from the ground at 14. m/s returns to the ground in 9. s
This means that it took 9 seconds from the time it left the ground until it fell back down. that's 4.5 seconds each way. When the stone reaches it's maximum height, it will have a velocity of 0 m/s. We know that it will impact the ground at a V of 14 m/s and it will take 4.5 seconds to go from 0 m/s to 14 m/s. So...
[tex]a = \frac{V}{t} = \frac{14 m/s}{4.5 s} = 3.11 m/s^2[/tex]
Actually that works out as well since the round trip took nine seconds and +14 m/s - -14 m/s = 28 m/s. So 28/9 is correct as well.
ugh, it's to late for this. :smile:
Not to nitpick, but isn't "same speed" more appropriate than "same velocity"?
Please, nitpick. I goofed. Yes, same speed would be more appropriate.
  • · Replies 38 ·
