Easier Method for Determining Convergence of a Series
  • Thread starter Thread starter G01
The discussion revolves around determining the convergence properties of the series \(\sum_{n=1}^{\infty} \frac{(-1)^n e^{1/n}}{n^3}\). Participants are exploring whether the series is conditionally convergent, absolutely convergent, or divergent, and are seeking simpler methods for analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using the ratio test and L'Hôpital's Rule, while questioning if there are easier methods. There is mention of showing absolute convergence by examining the series formed by the absolute values of the terms. Some participants suggest using the comparison test with a known convergent series.
The discussion is active, with various approaches being proposed. Some participants have offered guidance on checking absolute convergence and using comparison tests, while others are exploring the implications of the terms' behavior.
There is an emphasis on the complexity of the original approach and a desire to find a more straightforward method. The discussion includes considerations of the terms' behavior and convergence criteria without reaching a definitive conclusion.
G01
Is the following limit, conditionally covergent, abolutely convergent, or divergent?
[tex]\sum_{n=1}^{\infty} \frac{(-1)^n e^{1/n}}{n^3}[/tex]
To solve this i used the ratio test with help from L'Hospitals Rule. That took me forever and was really complicated. Can anyone think of an easier way?
Say you want to show that it's absolutely convergent. Then you need to show the series formed by taking the absolute value of each term of this series is convergent. The terms of that series approach 1/n3 from above. Can you show that:
[tex]\sum_{n=1}^\infty \frac{1}{n^3}[/tex]
converges? Then you have one more step left.
It is an alternating series with terms decreasing in absolute value towards zero.
That is sufficient to tell you whether the series diverges or converges.
Hmm, can I use a comparison test between
and
Letting the n'th term be called a(n), then you have:
[tex]|a(n)|\leq\frac{e}{n^{3}}[/tex]
what does this tell you?
