Calculating Required Passing Sight Distance for Safe Maneuver | Help Needed
  • Thread starter Thread starter Probie
The discussion revolves around calculating the required passing sight distance for a vehicle maneuvering on a two-lane highway. The problem involves various parameters such as vehicle speeds, acceleration rates, and distances related to the passing and slow vehicles.
  • Participants discuss the initial conditions and attempt to plot vehicle positions over time to visualize the passing scenario. There are questions about the calculations of time and distance, as well as the reasoning behind certain distances, such as the lengths of the vehicles involved.
Several participants have shared their calculations and reasoning, with some seeking verification of their work. There is an ongoing exploration of the assumptions made in the problem, particularly regarding the distances and speeds of the vehicles. While some guidance has been offered, there is no explicit consensus on the correctness of the calculations presented.
Participants are working under the constraints of a homework assignment, which requires them to show their work and reasoning. There is a focus on understanding the dynamics of the passing maneuver, including the perception/reaction time and the impact of vehicle lengths on the calculations.
Probie
passing equation - help please
I am really confused with this stuff, old timer needs some help...
A vehicle moving at a speed of 50 mph is slowing traffic on a two-lane highway. What passing sight distance is necessary, in order for a passing maneuver to be carried out safely?
Assume that the following variables have the values given:
Passing vehicle driver's perception/reaction time = 2.5 sec
Passing vehicle's acceleration rate = 1.47 mph/sec
Initial speed of passing vehicle = 50 mph
Passing speed of passing vehicle = 60 mph
Speed of slow vehicle = 50 mph
Speed of opposing vehicle = 60 mph
Length of passing vehicle = 22 ft
Length of slow vehicle = 22 ft
Clearance distance between passing and slow vehicles at lane change = 20 ft
Clearance distance between passing and slow vehicles at lane re-entry = 20 ft
You should also assume that the passing vehicle accelerates to passing speed before moving into the left lane.
The distance traveled by slow vehicle ??
The distance traveled by passing vehicle ??
The distance traveled by opposing vehicle ??
The time taken for passing vehicle to complete the pass ??
The relative distance ??
The clearance distance between opposing vehicle and passing vehicle upon lane re entry ??
Welcome to PF, Probie. You need to show some of your work before we can be of much help. I'd recommend that you make a plot of the two vehicles' position versus time to help you figure this out. Draw time on the horizontal axis and distance on the vertical axis. Then Draw a straight line for the vehicle that is getting passed -- he's going a constant 50mph. Then start to draw the line for the passing vehicle, given some of the initial conditions. That should help you to get started.
Okay I drew to lines like you said, and all I get is two black lines on my paper staring back at me. I do not know if this is right but this is as far as I can get, as I said old timer needs help (50). I do not kow how to find the time I think it is t = D/v but I am not sure, and if it is how do I find the distance? Call me stupid...maybe just to old to learn.
Relative distance = 84ft
So = speed of opposing veh
So = 60 * 1.46
So = 87.6 f/s/s
Ss = speed of slow veh
Ss = 50 * 1.46
Ss = 73 f/s/s
diff = 87.6- 73
diff = 14.6 f/s/s
Well first off, I'm about the same age, and I learn new stuff all the time. So no, you don't get to use that excuse.
Next, the question is a little hard to understand, but I'm guessing it's something like this:
-- Driver in back sees that the road is clear at time t=0, but takes 2.5 seconds to start doing anything.
-- At t=2.5s, rear driver accelerates at 1.47mph/s, and reaches 60mph 20ft behind the slower car. How long does this take, and how far back from the 20ft did the rear driver have to start?
-- Faster driver now traveling 60mph travels the 20ft + 22ft + 22ft + 20ft distance and pulls back in, completing the pass. (quiz question: Why 22ft twice?)
You should be able to start adding up the numbers and distances, and start answering some of the questions. You should also be able to start drawing the plot of the passing vehicle on your graph. Since he starts behind the slower car and going the same speed, for t=0s to t=2.5s, the passing vehicle's line will be below (behind) the other vehicle's line on the graph, and parallel to it. Do you see why?
EDIT -- Fixed a typo
You are reading the question properly, the time of 2.5 sec is called percetion/reaction time.
The two vehs are on the highway and when the way is clear to rear veh accelerates and passes.
But there is veh coming toward the passing veh at a speed of 60 mph.
Why 22 ft twice, because you must count the length of the veh being passed plus the length of the passing veh. (for instance what if the passing veh is 40 ft long, it would then take longer to clear the slower veh and also it would close the distance between the passing veh and the opposing veh sooner).
If I am doing this right so far I have come up with a time of 6.80 sec to reach a speed of 60 mph. from 50 mph.
60 - 50 = 10 / 1.47 = 6.80sec
Okay here is what I get (no laughing allowed):
A = acceleration V1 = rear veh V2 = lead veh D = difference in speed
D = V1 - v2
D = 60 - 50
D = 10 mph
T = D / A
T = (V1 - V2) / A
T = (60 - 50 ) / 1.46
T = 6.80 sec.
So the rear vehicle traveled started 147 ft back of the lead veh. Then at 20 ft behind the lead veh he pulled out to pass covering a distance of 88 ft in 5.98 sec. then pulled back into his own lane in front of the veh he passed.
diff. in speed of two veh = 10 mph
14.70 f/s/s = 10 * 1.47 f/s/s
D = 14.70 * 10
D = 147 ft.
The passing veh covered a distance of 599.76 feet during the passing manuver.
D = V * t
D = 88.2 f/s/s * 6.80 sec
D = 599.76
The opposing veh covered a distance of 599.76 ft at a speed of 60 mph.
So if the distance between the passing veh and the opposing veh was 1800 ft then the distance between the passing veh and the opposing veh on completion of the passing manuver was 453.38 ft
The distance traveled by slow vehicle = 499.80 ft
The distance traveled by passing vehicle = 746.76 ft
The distance traveled by opposing vehicle = 599.76
The time taken for passing vehicle to complete the pass = 6.8 sec
The relative distance = 88 ft
The clearance distance between opposing vehicle and passing vehicle upon lane re entry = 453.48 ft
Could someone please check my above post to see if I did this right. Thanks
Okay here is my work...someone please see if I am correct with this.
D = V1 - v2
D = 60 - 50
D = 10 mph
T = D / A
T = (V1 - V2) / A
T = 6.80 sec.
D = 14.70 * 10
D = 147 ft.
D = V * t
D = 599.76
Basically it looks right, but why 88 ft. instead of 84 ft?
Typo ...sorry about that.
  • · Replies 86 ·
9K
  • · Replies 17 ·
