The principle of the constancy of the velocity of light
This thread discusses the principle of the constancy of the velocity of light, particularly in the context of special relativity. Participants explore interpretations of Einstein's ideas, the implications of light's speed in different reference frames, and the synchronization of clocks in moving and stationary systems.
  • One participant interprets Einstein's principle to suggest that light emitted from a moving system travels at speed c - v in a stationary system, while light from a stationary system travels at speed c.
  • Another participant argues that this interpretation is incorrect, stating that the speed of light is always c in all inertial reference frames, regardless of the source's motion.
  • A different participant supports the claim that the speed of light remains constant across reference frames, providing reasoning based on the second postulate of special relativity.
  • One participant explains that observers in different frames may perceive light's travel time differently due to relative motion, but this does not imply a change in the speed of light itself.
  • Another participant references specific equations from Einstein's work to illustrate the relationship between time intervals and distances in different reference frames.
Participants express disagreement regarding the interpretation of light's speed in moving versus stationary systems. There is no consensus on the correct interpretation of Einstein's principle, with multiple competing views presented.
Some participants highlight the potential confusion arising from applying Newtonian transformation laws to relativistic scenarios, indicating a need for careful consideration of reference frames.
myoho.renge.kyo
in this thread i have quoted A Einstein. i give him all the credit for all the definitions and ideas (if I have interpreted them correctly). if I have not interpreted his ideas correctly, it is my fault, and i am sorry. i need help to interpret his ideas. that is why i join this forum. thanks!
all our judgments in which time plays a part are always judgments of simultaneous events. for example, if I say that at 11:00 pm, 9/16/2006, in Burbank, California, a train arrived, I am saying that the pointing of the small hand of my watch to 11:00 pm and the arrival of the train are simultaneous events.
A = a point of space where there is a clock and an observer who determines the time value of an event in the immediate proximity of A by finding the position of the hands (of the clock) which are simultaneous with this event.
B = a point of space where there is another clock (in all respects resembling the one at A) and another observer who determines the time value of an event in the immediate proximity of B by finding the position of the hands (of the clock) which are simultaneous with this event.
A time = the time value of the event in the immediate proximity of A (determined by the observer with the clock at A)
B time = the time value of the event in the immediate proximity of B (determined by the observer with the clock at B)
common A and B time = the time value of the event in the immediate proximity of either A or B (either one determined by either the obsever with the clock at A or the observer with the clock at B). a common A and B time cannot be defined unless we establish that the time required by light to travel from A to B equals the time required by light to travel from B to A. thus to say that there is now a common A and B time is to say that the clock at A and the clock at B synchronize.
stationary system (K) = a system of coordinates in which the equations of Newtonian mechanics hold good.
stationary rigid rod (k) = a stationary rigid rod lying along the axis of x of K. the length of k is l as measured by a measuring-rod which is also stationary. a uniform motion of parallel translation with velocity v along the axis of x of K is now imparted to k.
the length of k in the moving system (the moving system in this case is k itself) = l = the length of k ascertain by the following operation: an observer moving together with the given measuring-rod and k measures the length of k directly by superposing the measuring-rod, in just the same way as if all three were at rest.
the length of the moving system k in the stationary system K = rAB = the length of k ascertain by the following operation: by means of stationary clocks set up in the stationary system K and synchronizing, an observer ascertains at what points (x1 and x2) of the stationary system K the two ends (A and B) of the moving system k are located respectively at a definite time (tA). the observer then measures the distance between these two points by the measuring-rod already employed, which in this case is at rest
at the end A of the moving system k there is a clock, and at the end B there is another clock. these two clocks and the stationary clocks in the stationary system K synchronize. with the clock at A there is an observer, and with the clock at B there is another observer.
at tA (the time value determined by the observer with the clock at A) a ray of light departs from A towards B. at tB (the time value determined by the observer with the clock at B) the ray of light is reflected from B. and at t'A (the time value determined again by the observer with the clock at A) the ray of light reaches A again.
the principle of the constancy of the velocity of light states that "the ray of light moves in the stationary system K with the determined velocity c, whether the ray be emitted by the stationary system k or by the moving system k."
A. Einstein states in the Principle of Relativity, p 45, that
l = c * (tB - tA), where tA and tB = the time values measured by the observer with the clock at A and the observer with the clock at B. for these observers, the ray of light moves with the determined velocity c.
and that
rAB / (c - v) = (tB - tA), where tA and tB = the time values measured by the observers with the clock at x1 in the stationary system K and the observer at x2. for these observers, the ray of light moves with the determined velocity c - v.
so in essence he is also saying that the principle of the constancy of the velocity of light states that "the ray of light moves in the stationary system K with the determined velocity c if the ray is emitted by the stationary system k, but if the ray is emitted by the moving system k, the ray of light moves in the stationary system K with the determined velocity c - v."
why? or why not? thanks! (11:00 pm, 9/16/2006, thru 12:00 am, 9/17/2006, in Burbank, California)
this is wrong, the velocity of a ray of light is viewed as c from any reference frame no matter where it is emitted.
*edit*
according to the second postulate of special relativity, the speed of light is c in all inertial reference frames.
Hello,
As michael879 told you, the second postulate of SR says that the speed of light is the same in all inertial reference frame. This is logical ; why, for someone thinking he is at rest, the speed of light should be different when he is in his car or in front of his computer? This is the idea of SR, there is no difference between someone really at rest or someone moving, for someone else, at a constant speed and linear movement. The only difference is the point of view.
You said "the ray of light moves in the stationary system K with the determined velocity c - v." This is not true, light is light, no matter where. In K, even if k is moving, light has the same speed. The difference is that the ray of light travels along the x-axis, as the rod does. So when, in K, the light goes in the same direction than the rod, the ray takes more time to arrive to the end of the rod. So, the observer in K would say "I expect that for k, this ray of light takes also more time to travel the length of the rod, so it is like if the light ray was slower". K would make a mistake, because he applies the Newtonian transformation laws from his reference frame to the other, which is not what he should do. But, K could say that for him, it is like if the ray goes at the speed c-v compared to the end of the rod.
Do you understand the difference? In classical physics, K would have say "because, for me, it takes more time for the ray to arrive to the end of the rod, it is like if the rod was motionless and that the ray travels at the speed c-v. Where does the rod is motionless? In his reference frame!". In SR, because Nature seems to make no difference between reference frames, K would stop at "... the speed c-v.".
Is it clear what I tried to say? I know this is a mess... :smile:
A. Einstein says on p 42 in The Principle of Relativity the following:
(tB - tA) = rAB / (c - v)
(t'A - tB) = rAB / (c + v)
[when measured in the stationary system K]
and on p 45 the following:
For a ray of light emitted at the time t = 0 in the direction of the increasing x [when measured in the moving system k]
x = ct
But the ray moves relatively to the initial point of [the moving system k], when measured in the stationary system [K], with the velocity c - v, so that
x / (c - v) = t
why? thanks! (7:00 am thru 8:00 am)
since i was a kid i was facinated by Einstein's ideas. i always wanted to understand them. i am not here to refute his ideas. i am only here to understand them, and in the process of understanding, i might ask hard questions. thanks again.
Hello,
Imagine that you are near a road. There are two cars, a blue one (B) and a red one (R). Note the length of R as L. The experience is to mesure the time needed by B (which always travels at a constant speed) to traverse L.
First, imagine that R is motionless. At t=0, the front of B is aligned with the back of R. You can find that t' = L/v_B .
Second, imagine that R is moving at the speed v_R so v_R < v_B. At t=0, the front of B is aligned with the back of R. But, this time, R is moving, so it would take longer to B to traverse L. You can find the duration t'' needed by B to traverse R doing t'' = L/(v_B - v_R).
In CM, you apply your result as the result of R reference frame, which means that if B was rather a ray of light, for R, this ray would have a speed slower than c. But, there is no reason that your reference frame should be different than R's reference frame.
I would like to help you more, but I'm handicapped by my little knowledge in English. Sorry.
Zeit
x = ct
x / (c - v) = t
Ive never read Einstein's writing, I learned relativity from a textbook but this is wrong and your probably reading it out of context. What you said is the classical mechanics view of light, not einstein's relativistic view.
Read Chapter 22. Einstein said that the constancy of the speed of light in a vacuum is only applicable to the Special Theory of Relativity, and that in the General Theory, the speed of light in a vacuum must be variable, because refraction can only occur when the speed of light varies with location.
http://www.bartleby.com/173/
Sorry, but what myoho.renge.kyo quotes is true. As I said, if you do not directly apply this result to another reference frame (in which case we use Galileo's transformations, so classical mechanics). But, the fact is that Galileo was right... for an only reference frame...
Look at my example with the cars. I never apply my results as what R sees. But it is true that if, for me, a ray light traverses the length of a red car moving, it would take more time for the ray of light to traverse it than if the car was motionless. If you look at two photons traveling in the same direction, never the second photon would come closer of the first that it is now.
What myoho.renge.kyo quotes is Einstein's explanation of simultanneity concept, the idea that time (and we could find after that length also) is relative to each other.
I do not understand. Refraction occurs when a ray of light travels through two different transparent "locations" (sorry, I have not find a better word...). The slow down of speed of light is caused by the absorption-emmision of the photons. What does it have to do with GR? Thanks.
Einstein's derivation in his original 1905 paper (available online here) is a bit confusing, but when he talks about the light moving at velocity c - v, he's talking about how it would move in a coordinate system that was related to your first coordinate system K by a coordinate transformation which leaves y,z, and t unchanged, while replacing x with x-vt. This is not a valid inertial coordinate system in special relativity, it doesn't represent the measurements of any observer using rulers and synchronized clocks of the type Einstein introduced to define inertial coordinate systems.
If it helps, I tried to follow along Einstein's derivation in a post on a usenet physics group a while ago, I'll repost it here:
First Einstein assumes you have to coordinate systems defined by
measurements on a system of rigid measuring rods and clocks, K and k,
with all the spatial axes parallel and with k moving at velocity v along
K's x-axis. K's coordinates are (x,y,z,t) while k's coordinates are (xi,
eta, zeta, tau). Then he defines a new coordinate x'=x-vt, and says "it
is clear that a point at rest in the system k must have a system of
values x', y, z, independent of time". Although he doesn't state it this
way, what he has effectively done is to introduce a *third* coordinate
system Kg, with y,z,t coordinates identical to K, but with x' coordinate
given by x-vt. To make this a little clearer, I'm going to modify his
notation and say that coordinate system Kg uses coordinates x',y',z',t',
with these coordinates related to K's coordinates x,y,z,t by a Galilei
transform:
x'=x-vt
y'=y
z'=z
t'=t
An important thing to notice is that, unlike k and K, Kg doesn't
necessarily correspond to the measurements of any observer using a
system of measuring-rods and clocks; it isn't really an inertial
reference frame at all. So, the postulate that all observers must
measure the speed of light to be c in their own rest frame doesn't apply
to Kg. In fact, since we know light must travel at c in both directions
in K, and Kg is related to K by a Galilei transform, it must be true
that light travels at (c-v) in the +x' direction of Kg, and (c-v) in the
-x' direction of Kg.
So now a light beam is sent from the origin of k at tau0, reflected by a
mirror at rest in k at tau1, and returned to the origin at tau2. As
Einstein said, any point which is at rest in k must also be at rest in
this new coordinate system which I am calling Kg, so neither the point
of origin nor the mirror are moving in Kg. So if the origin of Kg
coincides with the origin of k, and if we say the mirror is at position
x'=xm' in Kg, then since light travels at (c-v) in the +x' direction of
Kg, the light will take time xm'/(c-v) to reach the mirror in Kg, and
since light travels at (c+v) in the -x' direction of Kg, it will take an
additional time of xm'/(c+v) to return to the origin. Thus, if the light
is emitted at t'=t0' in Kg's frame, it is reflected at t'=t0' +
xm'/(c-v), and returns to the origin at t'=t0' + xm'/(c-v) + xm'/(c+v)
So, if k's coordinate tau is expressed as a function of Kg's coordinates
like tau(x',y',z',t') then we have:
tau0 = tau(0, 0, 0, t0')
tau1 = tau(xm', 0, 0, t0' + xm'/(c-v))
tau2 = tau(0, 0, 0, t0' + xm'/(c-v) + xm'/(c+v))
Now, since k represents the actual measurements of a non-accelerating
observer using his measuring-rods and clocks, we know that light must
travel at c in both directions in this coordinate system, and since the
origin and the mirror are at rest in k, the light must take the same
amount of time to reach the mirror as it takes to be reflected back to
the origin in k. So, this gives 1/2(tau0 + tau2) = tau1, which
substituting in the expressions above gives
1/2[tau(0, 0, 0, t0') + tau(0, 0, 0, t0' + xm'/(c-v) + xm'/(c+v))] =
Then he goes from this to the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt')
= dtau/dx' + (1/c-v)*(dtau/dt'), which also confused me for a little
while because I didn't know what calculus rule he was using to go from
the last equation to this one. But then I realized that if you just
ignore the y' and z' coordinates and look at tau(x',t'), then since he
says "if x' is chosen infinitesimally small", you can just assume tau is
a slanted plane in the 3D space with x',t' as the horizontal axes and
tau as the vertical axes. The general equation for a slanted plane in
these coordinates which goes through some point xp', tp', and taup would be:
tau(x',t') = Sx'*(x' - xp') + St'*(t' - tp') + taup
Where Sx' is the slope of the plane along the x' axis and St' is the
slope of the plane along the t' axis. If we say this plane must go
through the three points tau0, tau1 and tau2 earlier, then we can use
tau0's coordinates for xp', tp' and taup, giving:
tau(x',t') = Sx'*x' + St'*t' + tau0
So, plugging in tau1 = tau(xm', t0' + xm'/(c-v)) gives
tau1 = Sx'*xm' + St'*(t0' + xm'/(c-v)) + tau0
And plugging in tau2 = tau(0, t0' + xm'/(c-v) + xm'/(c+v)) gives:
tau2 = St'*(t0' + xm'/(c-v) + xm'/(c+v)) + tau0
So plugging these into 1/2(tau0 + tau2) = tau1 gives:
1/2(tau0 + St'*(t0' + xm'/(c-v) + xm'/(c+v)) + tau0 ) = Sx'*xm' +
With a little algebra, this reduces to:
(1/2)*St'*(1/(c-v) + 1/(c+v)) = Sx' + St'*(1/(c-v))
And since tau(x',t') is just a plane, of course St' = dtau/dt' and Sx' =
dtau/dx', so this gives the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt') =
dtau/dx' + (1/c-v)*(dtau/dt') which Einstein got.
He then reduces this to dtau/dx' + dtau/dt'*(v/(c^2 - v^2)) = 0, which
is just algebra. He also says that light moves along the y'-axis and
z'-axis of Kg at velocity squareroot(c^2 - v^2), which isn't too hard to
see--a light beam moving vertically along the zeta-axis of k will also
be moving vertically along the z'-axis of Kg since these coordinate
systems aren't moving wrt one another, but in K the light beam must be
moving diagonally since k is moving at v in k, so if you look at a
triangle with ct as the hypotenuse and vt as the horizontal side, the
vertical side must have length t*squareroot(c^2 - v^2), and since z'=z
and t'=t the light beam must also travel that distance in time t' in
Kg's coordinate system. The same kind of argument shows the velocity is
also squareroot(c^2 - v^2) in the y'-direction.
Since tau(x',y',z',t') is a linear function (ie tau(x',y',z',t') = Ax' +
By' + Cz' + Dt'), then from this you can conclude that if dtau/dx' +
dtau/dt'*(v/(c^2 - v^2)) = 0 for a light ray moving along the x'-axis,
tau(x',t') must have the form tau = a(t' - vx'/(c^2 - v^2)) where a is
some function of v (so that dtau/dt' = a and dtau/dx' = -av/(c^2 - v^2),
which means dtau/dx' = (-v/(c^2 - v^2))*dtau/dt').
Next he says that in the k coordinate system the light ray's position as
a function of time would just be xi(tau)=c*tau, so plugging that
expression for tau in gives xi=ac(t' - vx'/(c^2 - v^2)). But in system
Kg, this light ray is moving at velocity (c-v), so its t' coordinate as
a function of x' is t'(x') = x'/(c-v). Plugging this in gives xi =
ac(x'/(c-v) - vx'/(c^2 - v^2)) = a*(c^2/(c^2 - v^2))*x'.
Similarly, if light is going in the eta-direction then eta(tau)=c*tau,
so plugging in tau = a(t' - vx'/(c^2 - v^2)) gives eta=ac(t' - vx'/(c^2
- v^2)). In Kg this ray is moving at squareroot(c^2 - v^2) in the
y'-direction, so t'(y')=y'/squareroot(c^2 - v^2), and plugging this in
gives eta= a(y'/squareroot(c^2 - v^2) - vx'/(c^2 - v^2))...since x'=0
for this ray, this reduces to eta=(ac/squareroot(c^2 - v^2))* y'. The
relation between zeta and z' is exactly the same, so we have:
xi = a*(c^2/(c^2 - v^2))*x'
eta = (ac/squareroot(c^2 - v^2))* y'
zeta=(ac/squareroot(c^2 - v^2))* z'
Since the relation between Kg coordinates (x',y',z',t') and K
coordinates (x,y,z,t) is just x'=x-vt, y'=y, z'=z, t'=t, we can plug in
and simplify to get:
tau = Phi(v) * Beta * (t - vx/c^2)
xi = Phi(v) * Beta * (x - vt)
eta = Phi(v) * y
zeta = Phi(v) * z
Where where Beta = c/squareroot(c^2 - v^2) = 1/squareroot(1 - v^2/c^2),
and Phi(v) = ac/squareroot(c^2 - v^2) (since a was an undetermined
function of v in the first place he just writes Phi(v)).
To find Phi(v), he then imagines a coordinate system K' which is moving
at -v relative to k (and unlike Kg, this coordinate system is supposed
to correspond to the measurements made on a system of measuring-rods and
clocks, so it's a valid inertial reference frame). *He uses
(x',y',z',t') for the K' coordinate system, but since I've already used
that for Kg, let's call the K'-coordinates (x",y",z",t"). Then the
transform from k-coordinates to K'-coordinates would have to be:
t" = Phi(-v) * Beta(-v) * (tau + v*xi/c^2) = Phi(v)*Phi(-v)*t
x" = Phi(-v) * Beta(-v) * (xi + v*tau) = Phi(v)*Phi(-v)*x
y" = Phi(-v) * eta = Phi(v)*Phi(-v)*y
z" = Phi(-v) * zeta = Phi(v)*Phi(-v)*z
If K' is moving at -v in the k-system, and k is moving at +v in the
K-system, then K and K' should really be the same system, so
Phi(v)*Phi(-v) should be 1. Then he argues that if you have a rod of
lenght l lying along the eta-axis of k and at rest in that system, then
if you transform the coordinates of its ends into the K-system, you find
that its length in the K-system is l/Phi(v), and by symmetry he argues
that the length of a vertical rod moving horizontally can only depend on
the magnitude of the velocity and not the direction, so l/Phi(v) =
l/Phi(-v), which means Phi(v) = Phi(-v)...combining with Phi(v)*Phi(-v)
= 1 which he obtained earlier, he concludes that Phi(v)=1, which gives
him the Lorentz transform.
yea, this is true from the frame of reference that sees the car as moving. The Earth's frame sees the light go at c-v compared to the car. However the light never appears to go at any velocity other than c from any inertial reference frame. The Earth frame still sees the light as going at c as does the car's reference frame.
This is often called the "separation velocity" of two objects which are moving in some inertial reference frame. It is not the same sort of thing as the velocity of a single object in some inertial reference frame, and the v < c restriction doesn't apply to it. Note that it does not equal the velocity of one object in the inertial reference frame in which the other one is stationary. To find that, you have to use the relativistic "velocity addition" formula.
Excuse for the question.
There is a person which can say to me an answer about speed of light?
The maximum speed of light is c, the result of michelson & morley experiment says: there isn't ether in space.
Is possible to say:
The photons generated by a light emitter was indipendent by a generator and then, there isn't anything that can "drag" the photons with sufficent force to measure the variation ( With exclusion of curvature of the rays by the high mass gravity)?
Is possible to say:
Ive seen your drag theory on another thread. c isn't just the maximum speed for light in an inertial frame, its the minimum too. your drag theory doesn't explain how when someone tries to "chase" a photon it still always goes at c relative to them.
alpaolo said:
Is possible to say:
No, the fact that Michelson-Morley expected the light to move at different speeds relative to the Earth has nothing to do with "drag". By analogy, suppose you see two cars driving by you, and they are moving at 80 mph and 50 mph. In Newtonian physics, in the frame of the car moving at 50 mph, the speed of the second car would be 80-50 = 30 mph. Nothing to do with drag, just a question of observers moving at different speeds measuring other objects to have different speeds relative to themselves. But in relativity this is no longer true; if I see a light beam go by me followed by a ship, and I measure the light beam to be moving at 1 c and the ship to be moving at 0.7 c relative to me, then the ship will not measure the light beam to be moving at 1 c - 0.7 c = 0.3 c relative to itself, instead it will measure the light beam to still be traveling at 1 c relative to itself. This has to do with the fact that in relativity, each observer uses their own rulers and clocks at rest relative to themselves to measure distances and time (and speed = distance/time), but each observer measures the rulers of other observers (which are moving along with those other observers in the first observer's frame) to be shrunk, and their clocks to be slowed-down and out-of-sync with each other.
You mean Gallilean, not Newtonian.
Newtonian physics uses the Galilei transform to describes measurements made in different inertial reference frames, so I guess either could be correct, although I don't usually see people using the phrase "Galilean physics", maybe since Galileo didn't really have any unified framework for describing physical laws like Newton's three laws of motion.
l = c * (tB - tA) ...
and that
rAB / (c - v) = (tB - tA) ...
Einstein's special theory says ...
Light's speed wrt the stationary measuring observer is c.
Light's speed wrt any moving body is c-v, per the stationary measuring observer.​
The reason light's speed is c wrt the stationary measuring observer is because v=0 since all inertial measurers assume themselves the stationary per their own vantage. So c-v = c-0 = c.
Some will cite that the medium supports only a speed c change. Some will suggest that light travels orthogonal to 3-space, and so we can never record a change in its speed as a function of own own material motion thru the 3-space. Light cannot be held in a state of rest, and so we can assume that light's dynamics are mutually linked to the intrinsic properties of the fused spacetime itself.
Actually, that is not the meaning of Einstein's equation there--see my first post on the thread where I went over Einstein's method, he was actually introducing a new coordinate system which was related to an actual physical coordinate system by a Galilei transform, and thus this new coordinate system would not correspond to the actual measurements of any inertial observer in relativity. The v was not an observer's measurement of his own velocity, but rather his velocity as measured in the "stationary frame" which was based on actual rulers and clocks. The coordinates that would actually be measured by this observer if he used his own rulers and clocks were denoted by the greek symbols tau, xi, eta, and zeta (ie. [tex]\tau, \xi, \eta, \zeta[/tex]).
JesseM said:
Actually, that is not the meaning of Einstein's equation there--.
Yes, I realize all that. I was just being simplistic, that's all. What I said is correct, but was not intended to replace the Lorentz Transforms, nor the Fitzgerald Contraction (which was the posted eqn actually). If you are considering light wrt yourself, or wrt another of your frame, v=0 and so c-v or c+v equals c. Just another simplistic way of looking at it, since c-v was in the derivation at hand. So I just responded in the context of the stated post.
Yes, I'll take a look at your post. I have myself been through the LT derivation a gazillion times over many years. It's clear that you have as well. Einstein relates the perspectives of frames K and k in his kinematic model, setting the outbound and reflection legs equal between perspectives, takes the partial derivatives, integrates, substitutes for x'=x-vt and x=ct, deduces no length change along orthogonal axes, deduces that direction of v has not effect on the length contraction, which all leads to the Lorentz Transformations. My nickel description here :wink:
  • · Replies 34 ·
  • · Replies 67 ·
  • · Replies 35 ·
  • · Replies 42 ·
  • · Replies 16 ·
  • · Replies 84 ·
