Is there Instantaneous Acceleration?
The discussion revolves around the concept of instantaneous acceleration, particularly in the context of a specific position function given by x(t)=8.5t^2-2t+6. Participants explore whether instantaneous acceleration can be considered constant or if it can vary, and they examine the implications of derivatives in this context.
  • Some participants propose that instantaneous acceleration is the acceleration at a specific time and is not always zero.
  • Others argue that in the provided function, the instantaneous acceleration is constant and equals 17, as it does not depend on time.
  • There is a question raised about how to determine if acceleration is constant and under what conditions it may not be.
  • Some participants mention the concept of "jerk," or the third derivative, suggesting that it could imply changing acceleration, but others clarify that in the given example, the jerk is zero.
  • A participant explains the process of finding acceleration through derivatives and provides an example where acceleration is zero, indicating no change in position over time.
  • There is a discussion about finding the rate of change of acceleration between two moving planets, with suggestions on how to approach this using derivatives of their position functions.
Participants express differing views on whether instantaneous acceleration can be constant or if it can vary, particularly in relation to the concept of jerk. The discussion remains unresolved regarding the broader implications of acceleration in different contexts.
Participants reference specific mathematical operations (derivatives) and their implications for understanding motion, but there is no consensus on the conditions under which acceleration may vary or remain constant.
brandtw
Is there such a thing as instantaneous acceleration or is it always zero? Problem gives: x(t)=8.5t^2-2t+6 and asks for instantaneous acceleration at t=3
Any help would be greatly appreciated
The instantaneous acceleration is just the acceleration at a particular time. In this case, it is certainly not zero. (Acceleration is the second derivative of distance with respect to time.)
thank you so with the distance equation x(t)=8.5t^2-2t+6 the instantaneous acceleration is 17?
Yep. And in this case, the acceleration is a constant: it doesn't even depend on the value of t.
thank you so much
how do you know it's a constant, and when would it not be constant?
If you are given the position function x(t), take the second derivative and see what happens.
i've learned today of a third derivative, which is a change or "jerk" in the acceleration. (a rate of change in a change of position) wouldn't that be changing always and never a constant?
Not at all. It depends. In the example that started this thread, the "jerk" is zero at all times.
Think of these simple examples:
- a body at rest = v=0, a=0, jerk=0
- a body moving with constant speed (in straight line): v=constant, a=0, jerk=0
- a falling body (no air resistance, etc.): v= changing, a=constant, jerk=0
Let us review first the definition of acceleration, and the question asked.
given a position [tex]x[/tex] which varies with time.
We know that the derivitve of that [tex]\frac{dx}{dt}[/tex] is the instantious time rate of change (derivative) of the position, which is given the name velocity. From that we take the derivative of that, so you have [tex]\frac{d^2x}{dt^2}[/tex] or the acceleration at an instant in time (given position)
Now, we are asked what the acceleration at [tex]t = 3[/tex] is. We are given the position function [tex]x(t)=8.5t^2-2t+6[/tex]. Therefore taking the second derivative [tex]\frac{d^2x(t)}{dt^2}[/tex] we find the derivative to be [tex]17[/tex]
Now consider if [tex]x(t) = t - 2[/tex] in which [tex]\frac{d^2x(t)}{dt^2}[/tex] would be 0. As you can see in the position function, no acceleration occurs, it is simply a constant position change based on time (indicating a constant velocity).
forstajh, the derivative is simply 17, not 17 m/s^2. No units were implied.
Correct notmuch, I apologize for any confusion this may have caused to anyone. I am so used to using m/s^2 that I accidently put them even though no units were provided.
Thanks for pointing out my error.
-Jacob
How does one find the rate of change of acceleration?
i.e. two planets moving toward each other.
Silverious, I am quite interested if someone has offered you any answers. please let me know.
Thank you
If you are given the position as a function of time for each object, say x1(t) and x2(t), then the distance between them is |x1(t)- x2(t)|. The rate at which the two objects are moving toward each other is the derivative of that. The acceleration of each object, relative to the other, is the second derivative.
Now, if you are actually referring to two object, planets, you know that F= ma and that, for gravity, F= GmM/r2 so you can find the acceleration of either one directly from that.
That is a good explanation. Thanks.
  • · Replies 18 ·
