Solving Finite Difference Equation: a_{n+1} - a_{n} = n^2
The discussion revolves around solving a finite difference equation given by a_{n+1} - a_{n} = n^2. Participants express varying levels of familiarity with this type of equation.
  • Some participants suggest using the method of undetermined coefficients, proposing a cubic form for the solution. Others express uncertainty about the equation and its solution methods.
There are multiple approaches being discussed, including the method of undetermined coefficients and referencing known formulas. Some participants have expressed appreciation for the guidance provided, indicating a productive exchange of ideas.
One participant notes being rusty on solving such equations, which may indicate a need for foundational clarification. There is also mention of needing a base case for the solution process.
Pyrrhus
Difference Equation
Hello, can anyone offer any insight on this equation? . I am very very rusty on solving this type of equations.
[tex]a_{n+1} - a_{n} = n^2[/tex]
Never even seen that one before :bugeye:
Use the method of undetermined coefficients.
Homogeneous solution: C, a constant
Particular solution: a quadratic in n
multiply the particular by n so that it shares no terms with the homogeneous, and you get a cubic:
an = An^3 + Bn^2 + Cn + D
Then solve for A, B, C, D. You will need a base case.
Edit: alternatively you could just look up the well-known formula for the sum of the first n squares.
Thanks, exactly what i was looking for.
