Solving the Equation: (1 + ~5/2)^2 = (1 - ~5/2) + 1
  • Thread starter Thread starter AAZZ
    Numbers
The discussion revolves around the equation (1 + √5/2)² = (1 - √5/2) + 1, with participants attempting to verify its validity and explore its implications within the context of algebra and number theory.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the algebraic manipulation of the equation, with one attempting to expand the left side and questioning if their approach is correct. Others challenge the validity of the original equation and suggest modifications to it. There are inquiries into the reasoning behind the statements made, particularly regarding the nature of the numbers involved.
The discussion is active, with participants exploring different interpretations of the equation. Some express confusion about the validity of the equation as stated, while others provide alternative perspectives and suggest that the original assertion may be incorrect. There is a mix of attempts to clarify concepts and share insights about related mathematical ideas.
Participants reference the Fibonacci sequence and the golden mean, indicating a broader context of mathematical concepts that may influence their understanding of the problem. There is also mention of potential misconceptions regarding mathematical definitions and properties.
AAZZ
Legend: ~ = root sign
e.g. ~10 = Root 10
^ = power
e.g. ^2 = power of 2
The equation is:
Show that (1 + ~5/2) ^ 2 = (1 - ~5/2) +1
Legend: ^ = power
I did the following:
(1 + ~5/2)^2
(1 + ~5/2) (1 + ~5/2)
1^2 + (~5)^2 + 2 ~5
___________________
2^2
1 + 5 + 2 ~5
____________
6 + 2 ~5
__________
Am I going the right way? At the end, I am still unable to prove that both are equal to each other.
The original statement:
[tex]( 1 + \frac{ \sqrt{5}}{2} ) ^2 = ( 1 - \frac{ \sqrt{5}}{2} ) + 1[/tex]
is not true. So, unfortunately, showing that it is true will be impossible.
However, if you change the + sign on the left side to a - sign, and put the 1's in the numerators, you'll have more luck.
[tex]( \frac{ 1 - \sqrt{5}}{2} ) ^2 = ( \frac{ 1 - \sqrt{5}}{2} ) + 1[/tex]
How so? What is the reason? I don't only want the answer, I want to understand the statement. Please explain if you don't mind. :)
But my teacher said it is. These are Fibonacci Numbers. Numbers that repeat themselves. I think I'm going nuts.
"The Fibonacci Sequence is 1,1,2,3,5,8,13,21,... It is based on the idealized reproduction rate of little rabits. It is named after the first known to have devised it.
For centures it had recursive difinition only. The definition is:
a1=1; a2=1; an+1=an + an-1"
I heard a teacher tell his kids the other day that 0 is not a real number since you can't divide by it, and that vairables that are represented by different letters (like x, y and z) cannot be the same numbers.
Teachers are not always right.
The number you are working with is called the golden mean. It's numerical value is:
[tex]\frac{1 + \sqrt{5}}{2}[/tex]
It is one of two values (the other has a - sign) that have the following property: they satisfy the equation:
[tex]x^2 = x + 1[/tex]
That is, when you square the number, you get the same thing as when you just add 1. Notice the structure of this equation compared to that of your numerical statement. It's not the same.
plug in the left and right side of the equation. They equal different things. I encourage you to convert your equation to LaTeX so as to not confuse, also.
vsage said:
plug in the left and right side of the equation. They equal different things. I encourage you to convert your equation to LaTeX so as to not confuse.
Do you mean evaluate the left and right side of the equation in a calculator? What should he "plug in"? He sounds like a young kid, so I don't think he'll be learning LaTex overnight.
  • · Replies 22 ·
