Light deflection at high speed
The discussion revolves around the deflection of light when the Sun is moving at high speed along the light ray. Participants explore the implications of this scenario from different reference frames, including the Sun's rest frame and the observer's frame. The conversation touches on theoretical aspects, relativistic effects, and potential explanations for the observed phenomena.
  • Some participants propose transforming to the Sun's rest frame to calculate deflection and then transforming back to the observer's frame, suggesting that deflection appears greater from different frames.
  • Others argue that the deflection remains the same regardless of the Sun's speed, with changes only in the observed color of the light due to redshift.
  • A participant mentions that the amount of deflection does not depend on the frequency of the light, asserting that light will deflect the same regardless of its color.
  • There is a suggestion that distances in the direction of motion contract while transverse distances do not, which could affect the observed angle of deflection.
  • Some participants inquire about alternative explanations in Post-Newtonian terms or avoiding Lorentz transformations, seeking a more complex understanding of the problem.
  • One participant questions whether the angle of deflection would increase if the observer moves closer to the Sun at high speed, suggesting a gamma factor effect.
  • Another participant clarifies that the discussion pertains to an observer moving with the Sun, leading to a simple special relativity problem regarding the observed angles of deflection.
Participants express differing views on whether the deflection of light changes with the Sun's speed. Some agree that the approach of transforming frames is valid, while others contest the idea that deflection would be greater in a moving frame. The discussion remains unresolved with multiple competing perspectives.
There are unresolved assumptions regarding the effects of relativistic speeds on light deflection and the implications of coordinate dependencies in the calculations. The discussion also highlights the complexity of explaining these phenomena without relying solely on established shortcuts.
Ich
Hi,
someone asked me how light would be deflected when the sun were moving at high speed along the light ray.
The simple answer is: transform in the sun´s rest frame, calculate the deflection and transform back to the observer´s frame. The result is that the deflection would be greater when viewed from a different frame.
I have now two questions:
1. Is this correct?
2. Is there a way to explain the result natively in the observer´s frame, something like a strengthening of the sun´s gravitational field in transverse direction, increase of the relativistic mass of the sun, or gravitomagnetics?
I hope someone can help.
Hard to tell what your talking about; but assuming you mean a beam of light coming toward the Sun & Earth such that you will see the deflection on earth.
Then you change the motion of the Sun & Earth in their common FrameOfRef to a speed of say 0.8c away from the source of the light you are watching.
The deflection will remain the same, the only difference will be in the color of the light you are observing as it red shifts. No change in math, mass, gravity or gravitomagnetics? As the light will still be traveling at “c” as observed by Sun and Earth. Just a different color.
Ich said:
Hi,
1. Is this correct?
Yes, the approach is correct.
As far as I know there are no correct shortcuts, i.e. the above is the simplest approach. It's certainly the most straightforwards approach.
Are you saying you agree that;
"The result is that the deflection would be greater when viewed from a different frame."
Which would mean light with a lower Hz (red) should deflect more than others light (blue). I don't think that is the case.
The amount of deflection will not depend on the frequency of the light.
The way I understand the problem is this:
At infinity, light will travel in essentially a straight line path. One pretends that space-time is flat everywhere, and then extends the straight-line course that light takes at infinity so that the two lines (the two lines being "before" and "after" the light encounters the mass) meet at a point. One then measures the angle between the two straight lines. This angle, measured entirely in flat space and flat space-time, is called the 'angle of deflection'. This is a coordinate dependent quantity. I'm not exactly clear on how pernicious the coordinate dependencies are in this problem, offhand.
I agree.
But the OP as I see it, is asking how would the deflection change with that some light if you were to change the Sun & its reference by moving it at a high speed in the same direction as the light. You seem to agree with the OP in your earlier post that the deflection would change (larger deflection) due to the movement of the Sun. I disagree, it should see the same thing as it already sees with other light coming by with more red shift and deflecting the same as the blue light. Because that is all that will happen to the original light, become more red, if the sun is moved as the OP asks.
Pretend everything is in flat space-time. Distances in the direction of motion will contract, while transverse distances will not. This will cause the angle to change.
Thanks for the answers.
Maybe I didn´t express myself very clearly, but pervect obviously understood what I meant: the deflection as measured in a frame moving relative to the sun.
Could you imagine a more complicated approach which treats the problem in the moving frame, avoiding the LT-shortcut? The one who asked me likes "explanations", not only the result. Is there a way to describe it in Post-Newtonian terms?
Is this true.
When I am standstill I measure angle 1.75"" of starligh deflected by the sun. When I very fast move closer to the sun (equivalently as sun move very fast) the distance to the star and sun become gamma times smaller. So the angle become larger?
OK you did not mean the “when the sun were moving at high speed along the light ray” from the OP.
Rather the question was just for an observer travel by the sun in the same direction as the photons being deflected.
Then the ‘explanation’ is a simple SR problem observing the triangle that forms the angle of deflection. The observer sees no change in the perpendicular side length but observes the length of the side parallel to the direction of relative travel as shorter. The changes in observed angles, as pervect pointed out, are then obvious.
  • · Replies 34 ·
  • · Replies 51 ·
  • · Replies 33 ·
  • · Replies 55 ·
  • · Replies 38 ·
  • · Replies 42 ·
