Calculating Min. D for .6nm Wavelength Difference & 1cm Diffraction Grating
The discussion centers on calculating the distance (D) required to resolve two wavelengths differing by 0.6nm using a 1cm diffraction grating with 105 slits. The derived formula for D is D = (dΔY)/(2Δλ), resulting in a calculated distance of 8.3mm. Participants express skepticism about the result, noting that the resolving power should increase with the number of slits, suggesting that the equation may not accurately reflect this relationship. The conversation highlights the importance of understanding the interplay between slit number and diffraction resolution.
  • Understanding of diffraction gratings and their properties
  • Familiarity with the intensity equation in optics
  • Knowledge of wavelength resolution in optical systems
  • Basic grasp of the relationship between slit number and resolving power
  • Research the principles of resolving power in diffraction gratings
  • Explore the impact of slit number on diffraction patterns
  • Study the derivation and application of the intensity equation in optics
  • Learn about practical applications of diffraction gratings in spectroscopy
Optics students, physicists, and engineers involved in designing optical systems or studying wavelength resolution in diffraction applications.
Jupiter
Consider two wavelengths that differ by .6nm and a 1cm diffraction grating that has 105 slits. How great must D (dist. to detector) be in order to resolve these wavelengths from a source containing them at better than ΔY=0.1mm?
From the intensity equation, I find that a maximum will occur whenever Yd/D=n2λ. So I need (solving for D)
[tex]D=\frac{d\Delta Y}{2\Delta \lambda}=8.3\textrm{mm}[/tex]. My work seems fine, but my answer seems off the mark. .6nm is a small wavelength difference. I'd expect a large D.
Verify anyone?
(d is the dist. between slit, which I take to be 1/105cm)
I am surprised no one can help me. Has no one ever studied this before?
  • · Replies 17 ·
