What is the acceleration of a simple pendulum at the lowest point of its swing?
The discussion revolves around calculating the acceleration of a simple pendulum at the lowest point of its swing. The original poster presents a scenario involving a pendulum with a specified mass and period, seeking to determine its vertical acceleration when it reaches the lowest point after being displaced from the vertical position.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the relationship between potential and kinetic energy, consider centripetal acceleration, and question the correct interpretation of height in the context of the pendulum's motion. There are discussions about using conservation of energy and the implications of displacement on height calculations.
The conversation is ongoing, with participants providing hints and guidance on the correct approach to the problem. There is recognition of the need to clarify the height measurement and its relation to the pendulum's position. Some participants express uncertainty about their calculations and seek validation of their reasoning.
Participants note the importance of understanding the pendulum's displacement angle and its effect on height calculations. There are also mentions of potential confusion regarding the distinction between vertical acceleration and forces acting on the pendulum at the lowest point of its swing.
Rockdog
A simple pendulum of mass 15 kg with a period of 1.8 sec is displaced an angle of 10 degrees from the vertical. What would its acceleration be in the vertical (y) direction as it reachs the lowest point on its swing?
Ok, I understand that it is a simple pendulum, but how do I figure out the acceleration?
Some help in the right direction would be helpful. I bet this is a simplistic problem, and I'm going to hit myself in the head when I figure out what it is.
Hint: the pendulum is centripetally accelerated. Start by figuring out the length of the pendulum.
Ok. R=2*pi sqrt(L/g)
L=.805m
I know that centripetal acceleration equals a = V^2/R
or can be rewritten as a= w^2*R
w equals 2*pi/T
w=3.49
T is the period or 1.8 seconds.
so a=3.49^2*.805 =>9.80 m/sec^2
Does that appear right? The computer says no, but all my calculations say yes.
L=.805m
Good.
Good.
w equals 2*pi/T
w=3.49
No! That would only be true for circular motion. The speed (or w) changes as the mass falls. Find the speed at the bottom. (Use conservation of energy.)
Ok, so use conservation of energy.
It starts off with potential energy, and then it gets converted to kinetic energy.
So it be mgh=.5mv^2
mass cancel out
so I'm left with gh=.5v^2
h=.805 m or h=.805m/cos 10
and I get v=3.972m/s
Then use a= V^2/R ?
Is this the right approach?
Yes, right approach. But be sure to use the correct value for h, measured from the lowest point.
Ok, maybe I'm missing something obvious. When the pendulum is directly vertical, isn't h going to be same thing as the length of the string?
No. "h" is the vertical distance the pendulum moves from initial position to final position. Think of h as Δy. When the pendulum is at its lowest point (vertical) call it y = 0. Find the intial value for y.
And remember that the pendulum was displaced only 10 degrees initially- not vertically above the lowest point.
This doesn't work.. I have a similar problem to work on.. I figured out my h by using trig, and even verified it by testing it in AutoCad... I also triple checked my units...
i put it into gh*2=v^2
and then took my v^2 and put it into a=v^2/2
and I'm still getting a wrong answer... the fundamental setup seems right but I think we're missing something big
So far, so good.
a = v^2/R, where R will equal the length of the pendulum.
If you still can't get it, show your work and we'll check it out.
Dare I suggest that there is NO vertical accelleration at the bottom of swing , but there is a vertical force f = m.V^2 / r ( centrifugal ) + m.g ( gravity) where v is the peripheral speed m/sec , r is radius , g is gravity m/s/s , these cause tension in the rod , but it is only the peripheral speed which keeps the pendulum swinging because it has kinetic energy at this point Ek = 1/2 . m. v^2 .
You did not say where exactly the mass was i.e. at the end of the pendulum or distributed --- r in the above means the distance to the center of mass if that's at the end of the rod then r is the pendulum length.
There is no problem viewing the pendulum from the usual inertial frame, in which case there is a centripetal acceleration (acting vertically) at the bottom of the swing. (Only when viewed from an accelerated frame would you introduce a "centrifugal" force.)
It is certainly true that it is the speed of the pendulum at the bottom of its swing that keeps it moving.
It's a simple pendulum. The mass is at the end of the rod.
I was getting the right answer all along.. I actually did the problem right myself before I started searching for help... I didn't notice that it was asking for the answer in cm.. sorry guys.. thanks for the help...
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 21 ·
