NH Science Bulletin: Ranking Forces in a Stack of Blocks
  • Thread starter Thread starter KillianHawkIII
    Concept Forces
The problem involves ranking the forces exerted by three blocks stacked on top of each other, specifically focusing on the interactions between the blocks and the forces acting on them due to gravity and normal forces.
  • Participants discuss the forces acting on each block, questioning the nature of the forces when blocks are not in contact and the implications of a net force of zero in a static scenario. There are attempts to understand the normal forces and how they relate to the weights of the blocks above.
Some participants have provided guidance on using free body diagrams to analyze the forces acting on each block. There is an exploration of the relationships between the weights of the blocks and the normal forces, with multiple interpretations being considered regarding the forces at play.
Participants are working under the assumption that the blocks are at rest on a surface, which influences their reasoning about the forces involved.
KillianHawkIII
The problem is to rank the forces exerted from three blocks on top of each other.
Like so:
[10 kg] #3
[5 kg] #2
[2kg] #1
Here is my reasoning,
From least force, to most force:
a. Force of block #1 on #3; They don't touch, so net force = 0
b. Force of #3 on #1; same thing, net force = 0
c. Force of #1 on the floor; which is just m1*g
d. Force of floor on #1; normal force against just block #1? Equal to c?
e. Force of #2 on #1; m2*g
f. Force of #1 on #2; normal force against #2?
g. Force of #3 on #2; m3*g
h. Force of #2 on #3; normal force against #3?
Is that how it is suppose to work? It doesn't seem right, but I can't figure out which concept I am understanding wrong.
Like so:
[10 kg] #3
[5 kg] #2
[2kg] #1
No.
Do a freebody diagram for block 1 (a diagram showing all the forces (vectors) acting on block #1). What is the net force? (hint: does it accelerate? - I think we are to assume that the blocks are sitting on a surface at rest). What does this tell you about the magnitude of the downward and upward forces? What is the upward force? What are the downward forces on #1?
AM
Ok, there is no acceleration, because nothing is moving, so the net force of the entire stack must be 0. For block #1, the weights of #2 & #3 combined is the force downward on it, and the force of the floor on #1 is the normal force of the weight of #'s 1-3? Does each block not have any normal force against the block on top of it then?
You just have to do a free body diagram for each block and set the resulting force to 0. The downward forces on each block are its weight plus the weight of those blocks above it. The upward force is the normal force from the floor. They sum to 0. To figure out what the normal force is on a block, do the free body diagram for that block.
AM
  • · Replies 17 ·
  • · Replies 21 ·
