How Can I Use BitSpirit for Torrents on a College LAN with Restricted Access?
  • Thread starter Thread starter himanshu121
The discussion revolves around the use of BitSpirit for downloading torrents on a college LAN with restricted access. Participants explore the implications of using torrent software in an academic environment, the potential for legal file sharing, and the challenges posed by network restrictions.
  • One participant seeks assistance in configuring BitSpirit behind a college LAN, noting that only port 53 appears open.
  • Another participant questions the legitimacy of using BitSpirit on a college network, suggesting that IT policies likely prohibit it and warning of potential legal consequences.
  • Some participants argue that many legal files are distributed via BitTorrent, emphasizing its efficiency in file distribution without overloading servers.
  • There is a contention that while the BitTorrent protocol is often associated with illegal file sharing, it can also have legitimate academic applications, and the OP should verify the network's policy on such software.
  • One participant points out that the application layer nature of torrents does not justify blanket bans on their use, as many legitimate applications utilize peer-to-peer technology.
Participants express differing views on the legitimacy and appropriateness of using BitSpirit for torrents in a college setting. While some advocate for the potential academic uses of torrents, others emphasize the risks and restrictions likely imposed by the college's IT policies. No consensus is reached on whether using BitSpirit is advisable or permissible.
Participants highlight the importance of clarifying the college's IT policies regarding torrent software, as well as the legal implications of using such software on a college network. There are unresolved questions about the specific restrictions in place and the potential for legitimate use cases.
himanshu121
Hi,
I am trying to set the settings for bitSpirit behind the college LAN(so i don't hv any access to router incase they are using), is there any way out that will allow me to download the files via torrents
portmapping is saying all my ports are closed except port no 53?
Thnks if anyone can help me out with this
Computer science news on Phys.org
Why? In all likelihood, your IT policy forbids it. What legitimate academic use can you have for a BT client?
Port 53 is usually used for DNS, so you shouldn't attempt to tie that up with BT. Besides, any reasonably alert sysop will know if you install/use BT software or if you attempt to install a firewall tunnel. Illicit File sharing on a college LAN can expose both you personally and your college to huge lawsuits, and can derail your whole future. So keep the consequences in mind.
many legal files are distributed using bit-torrent. Its a very efficient way of distribution if you can't afford/ or don't want to have a heavy load on your server
No doubt, but the fact remains that at this time, the BT protocol is used more for illegal FS than legal FS. Because of this, and other reasons, most universities prohibit the installation of BT software on their workstations. The OP must clarify that such a thing is allowed on his network. But if it's legit, even his own IT dept will help out with it, I'm sure.
Well Torrent is actually an application layer protocol (p2p), right? Which sits on top of tcp/ip. So should be ban IP because it can be used for illegal purposes? Nope.
So jumping to conclusions regarding torrents use isn't useful. Many open source files are distributed this way. In fact some voip apps use p2p. I can think of numerous *academic* uses for using Peer 2 peer technology.
20K
