Three blocks, two suspended, one on an incline
  • Thread starter Thread starter lizzyb
    Blocks Incline
The discussion revolves around a physics problem involving three blocks connected by ropes, with two blocks suspended and one on an incline. The problem includes variables such as mass, tension, friction, and gravitational force, and participants are attempting to analyze the forces acting on the blocks to determine acceleration and tension in the ropes.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants share their equations of motion for the blocks and discuss different setups for the problem. Some participants attempt to derive acceleration and tension values based on given masses and angles, while others express confusion over their calculations and results.
Some participants have provided calculations for acceleration and tensions, with mixed results regarding correctness according to a homework server. There is ongoing exploration of the relationships between the variables and how to properly sum the equations. Participants are questioning their approaches and seeking clarification on specific steps in the problem-solving process.
Participants are working under the constraints of a homework assignment, with specific values provided for masses, angles, and coefficients of friction. There is mention of limited attempts remaining for submitting answers, which adds pressure to find the correct solution.
lizzyb
Hi. I'm having a dickens of a time coming up with the correct answer for this.
I shall describe the question as it includes an image. There are three blocks altogether, b_1, b_2, b_3, each with a mass m_1, m_2, and m_3, respectively, and the blocks are all connected together by two ropes, T_1 between b_1 and b_2, and T_2 between b_2 and b_3. Blocks b_1 and b_3 are hanging from a pulley at the end an incline that has an angle of theta degrees (going up from left to right, b_1 on the left, b_3 on the right) and on this incline is b_2 which has a friction coefficient mu.
I've set it up a bunch of different ways but have not found the correct solution. Here is the last version:
m_1 g - T_1 = m_1 a
T_1 + sin(theta) m_2 g - mu cos(theta) m_2 g - T_2 = m_2 a
T_2 - m_3 g = - m_3 a (*)
For *, This was the last attempt to I made the acceleration negative (I tried it positive before).
Any help would be greatly appreciated! Thanx, lizzy
let @ = incline angle (theta)
u = friction coefficient
(m1)g - T1 = (m1)a
T1 + (m2)gsin@ - u(m2)gcos@ - T2 = (m2)a
T2 - (m3)g = (m3)a
sum the three equations ...
(m1)g + (m2)g(sin@ - ucos@) - (m3)g = a(m1 + m2 + m3)
solve for "a" now?
thankx
Thank you for your response.
For m_1 = 7.5, m_2 = 2.7, m_3 = 2.5, @ = 24, u = 0.15, I came up with 3.91561. I entered it into the homework server but it said my answer was wrong and that was my last chance at the solution.
There are two other questions related to it though which I might be able to get right with your help:
What is the tension in the cord connected to the 2.5 kg block (b_3)?
* I answered 34.289 but that was wrong.
What is the tension in the cord connected to the 7.5 kg block (b_1)?
* I have not answered this one at all yet (but I have more than one shot of an answer, I think 7 altogether)
Thank you! :-)
using your data, I get a = 8.3 m/s^2
a = -------------------------------------
(m1 + m2 + m3)
7.5 * 9.8 + 2.7 * 9.8(sin(24) - .15 cos(24)) - 2.5 * 9.8
( 7.5 + 2.7 + 2.5)
56.1364
= ------------ = 4.42019
12.7
does that not look correct?
T2 = (m3)a + (m3)g = 2.5 * 4.42019 + 2.5 * 9.8 = 35.5505
** That's right according to the homework server **
T1 = (m1)g - (m1)a = 7.5 * 9.8 - 7.5 * 4.42019 = 40.3486
** right again! **
When I first tried to solve for a, I forgot to put in the g next to m2.
My original equations were just like yours but I tried to solve it by solving for T1 and T2 and then substituting those in - that must have been where I messed up I suppose - is there something special to summing the equations?
Thank you for all your help.
  • · Replies 68 ·
14K
  • · Replies 33 ·
11K
