Normal force on an inclined plane
The discussion centers on calculating the normal force exerted by a frictionless inclined plane on a crate with a mass of 100 kg, pushed at a constant speed up a ramp inclined at 27.0°. The initial calculation incorrectly assumed that the horizontal force F had no vertical component. The correct approach requires considering both the horizontal force and the gravitational force acting on the crate. The normal force N can be accurately calculated using the equation N = mg cos(θ) + F sin(θ), where F is the horizontal force applied.
  • Understanding of Newton's laws of motion
  • Basic trigonometry for resolving forces
  • Knowledge of inclined plane physics
  • Familiarity with free-body diagrams
  • Study the concept of equilibrium in physics
  • Learn how to resolve forces on inclined planes
  • Explore the effects of applying forces at angles
  • Investigate the role of friction in inclined plane problems
Students studying physics, particularly those focusing on mechanics and inclined planes, as well as educators looking for examples of force analysis in real-world applications.
mbrmbrg
A crate of mass m = 100 kg is pushed at constant speed up the frictionless ramp (theta= 27.0°) by a horizontal force F.
What is the magnitude of the force exerted by the ramp on the crate?
My x-y coordinate system has x+ pointing up the ramp.
I assume that the force in question is the Normal force, which points directly along my positive y-axis.
No acceleration in the y direction (or x direction either, but that's irrelevant for this part of the problem), so
[itex]\Sigma\\F_{y}=N-mg_{y}=N-mg\cos\theta=0[/itex]
which gives [itex]N=mg\cos\theta=(100kg)(9.81m/s^2)(cos27^o)=874N[/itex]
But that's not the right answer... (and I don't know what the right answer is, either)
Help?
Help?
Constant velocity implies that the resulting force exerted on the crate has to equal zero. First write the equation of equilibrium for the assumed x-direction, to obtain the magnitude of the force F. Then write the equilibrium equation for the y-direction, to obtain the magnitude of the normal force N exerted on the crate from the ramp. Your mistake was that you did not include the pushing force F in your equation.
Got it; even after I tilted my coordinate system, I assumed that a horizontal force has no y-component. Bad thing.
Thanks!
  • · Replies 41 ·
  • · Replies 21 ·
  • · Replies 16 ·
