Is There a Friction Force on Block 1 in a Three-Mass Pulley System?
  • Thread starter Thread starter nightflarer
    Mass Pulley
The discussion revolves around a physics problem involving a three-mass pulley system, specifically focusing on the interaction between two blocks and the presence of friction forces. The original poster describes a scenario where block 1 is on top of block 2, which is on a table, with a hanging mass connected via a pulley. The problem includes coefficients of friction and asks whether a friction force exists between the blocks when block 1 is slipping.
  • Participants discuss the existence and direction of the friction force between block 1 and block 2, questioning the application of static versus kinetic friction based on the motion of the blocks. Some participants express confusion over the teacher's assertion that no friction force exists despite previous teachings suggesting otherwise.
The conversation is ongoing, with participants exploring different interpretations of the friction force based on the conditions of motion. Some guidance has been offered regarding the relationship between motion and friction, but no consensus has been reached regarding the original poster's confusion.
There is a noted distinction between scenarios where the blocks are at rest versus when they are in motion, which influences the presence of friction. The original poster also references a previous problem that may have influenced their understanding of the current situation.
nightflarer
Block 1 of mass m_1 is placed on block 2 of mass m_2 which is then placed on a table. A string connecting block 2 to a hanging mass M passes over a pulley attached to one end of the table. The mass and friction of the pulley are negligible. The coefficients of friction between blocks 1 and 2 and between block 2 and the tabletop are nonzero and are given in the following table (coefficient between blocks 1 and 2 for static friction is u_s1, for kinetic it's u_k1, for coefficient between block 2 and tabletop, static friction coefficient is u_s2, for kinetic it's u_k2.
Basically, you're supposed to find the acceleration of block 1 and 2, assuming M is large enough that as the hanging block descends, block 1 is slipping on block 2. There are some other questions too.
This was a test question, and I got it right for the most part. One of the questions was whether or not there existed a friction force f_1 exerted on block 1 by block 2, and if so, in what direction. I said there would be one of magnitude m_1*g*u_s1, and that's what a lot of my classmates thought since that's how the teacher had taught us in a problem we did a few weeks ago. However, now she says there is no friction force. What's up?
By the way, does anyone know where I can get access to old AP Physics Mechanic tests, especially the free responses? They'd be a good help for me for preparing for tests in the future. Thanks a lot.
Assuming your description of the problem is accurate, of course there's a friction force between the two blocks. But since you earlier said that block 1 is slipping on block 2, why did you use the coefficient of static friction?
Doc, the part I was referring to was a different section where M was small enough so that the blocks remain at rest when released. Sorry if that was unclear.
Big difference. If the blocks don't move there will be no friction force between them. (Just like if you rest a book on a horizontal surface: What's the friction force on it? None. If you try to push it and it resists, then there's a friction force involved.)
  • · Replies 18 ·
