Deriving Formula to Solve Least Force Needed for Board Against Wall
The discussion centers on deriving the formula for the least force needed to hold a board against a wall, specifically using the equation F=mg/f. Participants clarify that this formula is derived from free-body analysis, where the net forces acting on the board must equal zero. The relationship between the frictional force and the weight of the board is emphasized, with the equation Ffrict = mg x f being a key component in understanding the equilibrium conditions necessary to prevent the board from sliding. The confusion regarding the division of mg by f rather than multiplication is also addressed.
  • Understanding of Newton's Second Law (F=ma)
  • Knowledge of free-body diagrams in physics
  • Familiarity with concepts of friction and equilibrium
  • Basic algebra for manipulating equations
  • Study the derivation of forces in free-body diagrams
  • Learn about static friction coefficients and their applications
  • Explore equilibrium conditions in physics problems
  • Investigate real-world applications of F=mg/f in engineering scenarios
Students of physics, engineers, and anyone interested in understanding the mechanics of forces and equilibrium in physical systems.
caseys
In solving the problem of the least force needed to hold a board against the wall to prevent it from sliding down when the cof is known...the formula of F=mg/f was used to come up with the correct answer. Having found this formula in solving the problem it would be beneficial to also understand where this formula was derived from.
When looking at F=ma, a=gf, F=mg ...I just can not the way to derivating where the formula to solve the problem came from. Appreciate a boot in the correct direction...
I wouldn't normally call something like this a formula. It is "derived" from a free-body-analysis, in which the net forces acting on the ladder in the x and y directions must be equal to zero. They are a certain set of conditions for a given physical situation which can lead you to definite solutions such as the "formula" you mention.
If you draw such a diagram, you will see that at all times, for the ladder to remain in equilibrium, the reaction force from the wall will be equal to the frictional force, Ffrict = mg x f.
Thanks mezarashi...that is what I was thinking also of Ffrict = mg x f ... however, to come up for the correct answer for the problem it was neccesary to use mg/f ... just could not understand why the mg was divided by f rather than multiplied.
  • · Replies 18 ·
