Chemistry Pre-Lab Question
by ldixon
Tags: chemistry, prelab
ldixon
ldixon is offline
#1
Sep27-06, 08:36 PM
P: 17
I have a question on a pre-lab that I have to do. The question is:
You determine that test tube number 3 is an acid. It is colorless, odorless and has a very low pH value. You test the sample with all eight(8) reactants available and find no reaction(NR). What is the acid? Explain your answer.
The 8 reactants in the lab are:
KOH
AgNO3
BaCl2
NaCl
NH3(aq)
Ba(OH)2
H2SO4
Cu(NO3)2
I could not figure this out, it seems to me that every acid would react with at leat one of these? Is there an acid that would have no reaction with all of these?
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
Stevedye56
Stevedye56 is offline
#2
Sep28-06, 06:20 PM
P: 398
Start out with what you know is not an acid, then determine which is a noteable strong acid and cancel that. this will help you start out
ldixon
ldixon is offline
#3
Sep30-06, 02:44 PM
P: 17
Im not sure what you mean, I dont know what the acid is that has no reaction with all 8 of the listed reactants?
Stevedye56
#4
Sep30-06, 06:07 PM
P: 398
do you know what every acid contains in it? if not what about a base? Also does you book give a list of salts?
ldixon
ldixon is offline
#5
Oct1-06, 06:27 PM
P: 17
Yes acids contain H+ and bases contain OH, and yes I think there is a list of salts in the book.
Stevedye56
#6
Oct1-06, 06:42 PM
P: 398
im not quite sure what they mean by "low" on the pH scale if low means a low number such as 1 or 2 then its strong, if it means a low number implying that its weak it would be like 6-6.5. Is that exactly what the question reads as written? If so it may be a little more complicated than i originally though
ldixon
ldixon is offline
#7
Oct1-06, 06:52 PM
P: 17
yes low PH means a low number, the problem is written just like that. I can not figure anything out for it.
Stevedye56
#8
Oct1-06, 07:05 PM
P: 398
I originally read the problem thinking which one of the given 8 acids/bases/salts were the acid which i knew was easy. Re-reading it however i noticed that you need to know what acid it would be. I did a little searching to help you and came up with this. http://www.wwnorton.com/chemistry/co...ter5/ch5_4.htm
Strong bases= Very good electrolytes
ldixon
ldixon is offline
#9
Oct1-06, 09:13 PM
P: 17
Ok I think it would be HNO3 because it is always soluble with no exceptions, so there would be no visual reaction? Does that sound legit?
Stevedye56
#10
Oct2-06, 04:27 AM
P: 398
Yes, that sounds legit to me.
Stevedye56
#11
Oct2-06, 12:51 PM
P: 398
Reading over the main question yet another time does it imply that nr is not taking place because nothing visually happened? If so i agree with you.
Register to reply
Related Discussions
Chemistry in the Real World - Super Quick Question on chemistry/pools Biology, Chemistry & Other Homework 1
Chemistry Question Biology, Chemistry & Other Homework 4
chemistry question Introductory Physics Homework 11
Chemistry Question Introductory Physics Homework 6
Chemistry Question Chemistry 4
