PERE'S LAW, ELECTRIC FIELDS, AND RESISTANCE CALCULATIONS IN A MULTI-SECTION ROD
  • Thread starter Thread starter tigert2004
    Current Resistance
The discussion revolves around a problem involving electric fields and resistance calculations in a multi-section resistive rod. The rod is described as having three sections of equal length but differing radii, with specific electric field magnitudes provided for each section.
  • Participants discuss the electric fields and resistivity of the rod, questioning the validity of the rod's length and its implications. There are attempts to clarify the question regarding the radii of the first and second sections, and suggestions to calculate voltage and resistance based on the electric fields.
The discussion is active, with participants exploring the relationships between electric fields, voltage, and resistance. Some guidance has been offered regarding calculating voltage drops and resistance proportions, but there is no explicit consensus on the interpretation of the problem or the correct approach to finding the unknown radii.
There is uncertainty regarding the length of the rod, with one participant suggesting that 9 mm may not be appropriate for a rod. The original poster's question about the radii of the first and second sections is central to the discussion.
tigert2004
Figure 26-24a gives the magnitude E(x) of the electric fields that have been set up by a battery along a resistive rod of length 9.00 mm . The rod consists of three sections of the same material and length but with different radii. The radius of section 3 is 5.00 mm.
E for section 1 is 2.5e3V/m, E for section 2 is 4e3V/m,
E for section 3 is 1.5e3V/m
I understand that p is the same for all of them put I am getting stuck after that
What is the question?
Check the length. 9 mm can't be right if it is a rod. It must be 9 m.
You can find the applied voltage and voltage drops across each section easily enough from the electric field and lengths. You also can determine the resistance of each section in proportion to the resistance of the other sections or the total resistance.
All we need to know is the question.
AM
I am sorry, The question is what is the radius of the first and second section. The length is 9 mm. I can find V by equaling it to LE.
Well the length doesn't really matter but if it is 9 mm, it is wider than it is long, hardly a rod.
Find the total applied voltage and voltage drops across each section.
With that, you can find the proportional resistance of each section. How is resistance related to resistivity, length and area? Use that information to find the relative areas of each section and use the area of section 3 to find the areas and radii of the other two.
AM
