Find the sum of 1/((n)(n-1)) from n = 1 to 100
  • Context: Undergrad
  • Thread starter Thread starter PrudensOptimus
    Sum
The discussion revolves around finding the sum of the series 1/((n)(n-1)) from n = 1 to 100. Participants explore various methods for evaluating this sum, including partial fractions and approaches based on inhomogeneous sequences.
  • One participant suggests using partial fractions to simplify the sum.
  • Another participant points out that the fraction is undefined at n=1 and questions whether to start the sum at n=2 or to use an alternative expression, 1/n(n+1).
  • A participant proposes a general approach using logarithmic identities to derive the sum, leading to a formula involving n.
  • Another participant introduces a method based on the theory of inhomogeneous sequences, suggesting a form for the sum and providing specific values to determine constants.
  • It is noted that the derived formula holds for all values of n greater than those used to calculate the constants.
Participants express differing views on the starting point of the sum and the validity of the proposed methods. There is no consensus on a single approach or solution, as multiple methods and interpretations are presented.
Some limitations include the undefined nature of the original fraction at n=1 and the dependence on specific values used to derive constants in the inhomogeneous sequence approach.
PrudensOptimus
Find the sum of 1/((n)(n-1)) from n = 1 to 100.
Any idea?
Partial fractions!
write 1= n-(n-1)
One "idea" I have is that the sum does not exist. The fraction is undefined when n= 1. Did you mean to start at n= 2 or would you prefer to use 1/n(n+1)? (which would be the same thing)
Let SUM=∑k=2 to n [1/(k(k-1)] (1)
Apart from the straightforward method using partial fractions the seeked sum can be found from a more general approach (as a particular solution).
Let
S=ln[(x+2)/(x+3)]+ln[(x+3)/(x+4)]+...+ln[(x+n)/(x+n+1)]
S=ln{[(x+2)/(x+3)]*[(x+3)/(x+4)]*..*[(x+n-1)/(x+n)]*[(x+n)/(x+n+1]}
S=∑k=2 to n [ln(x+k)-ln(x+k+1)]=ln(x+2)-ln(x+n+1)
By deriving both members --->
S'=∑k=2 to n [1/(x+k)(x+k+1)]=[(n-1)/(x+2)(x+n+1)]
If we put now x=-1 results:
SUM=∑ k=2 to n [1/(k(k-1)]=(n-1)/n=1-(1/n) (2)
The adavantage of this method is clear,the general formula depending on x can be particularized to find other sums,∑ k=1 to n [1/(k(k+1)] for example,and so on.
There is another solution based on the theory of inhomogeneous sequences.The sum (depending only by 'n') must be seeked in the form:
SUM=(A/n2)+(B/n)+C (1)
A,B,C=constants
We know that:
S[n=2]=1/2 (2)
S[n=3]=2/3 (3)
S[n=4]=3/4 (4)
s[n=5]=4/5 (5)
S[n=6]=5/6 (6)
Introducing (1) in (2) (3) & (4) and solving the system --->
A=0
B=-1
C=1
Therefore SUM=(-1/n)+1=1-(1/n) (7)
Introducing now in (7) n=5 ---> S[n=5]=4/5 that is exactly (5) (for n=6 we obtain again an equality).The solution obtained is exact and holds for all values of 'n' (actually the inhomogeneous theory requires to prove that the sequence made with the free terms-here the general terms in 'n'=[1/(n(n-1))]-constitute a linear sequence but in practice it is enough to show that the obtained equation S=f(n) holds exactly for n greater than the values used to calculate the constants).
