How Do You Find a Tangent Line to f(x) = x^2 + 4 That Passes Through (0,0)?
  • Thread starter Thread starter teken894
    Lines Tangent
The discussion revolves around finding a tangent line to the function f(x) = x^2 + 4 that passes through the point (0,0). Participants are exploring the relationship between the function's derivative and the conditions for tangency.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the derivative of the function and its implications for the slope of the tangent line. There are attempts to clarify the distinction between the point of tangency and the external point (0,0). Some suggest using Newton's method, while others propose a more straightforward approach involving the equation of the tangent line.
The discussion is active, with various approaches being considered. Some participants have offered guidance on how to set up the problem, while others are questioning the assumptions about the relationship between the tangent line and the function.
There is a noted confusion regarding the point (0,0) not being on the graph of the function, which raises questions about the setup of the problem. The need to identify the correct point of tangency is emphasized.
teken894
Seems like a simple problem, but I have no idea how to accomplish this!
f(x) = x^2 +4
I have to find a tangent line to the graph that passes through the point (0,0).
I know the derivative is 2x, but I don't know how to mathematically figure out the which (x,f(x)) the tangent line would pass through..!
Any help would be appreciated
If the derivative is [tex]2x[/tex], then the slope at [tex](0,0)[/tex] will be [tex]0[/tex]. So its just a horizontal line through [tex](0,0)[/tex]
I know that.
You seee (0,0) is not a point on the graph. (0,0) is a given point (outside the graph) which I need to find a line tangent to the graph with.
http://66.93.135.68/tmp_pic.jpg
you have to use Newtons method [tex]x_{n+1} = x_{n} - \frac{f(x_{n})}{f'(x_{n})}[/tex]
You could do it in a simpler way.
[tex]f(x) = x^2 + 4[/tex]
[tex]f'(x) = 2x[/tex]
Let [tex]g(x) = f'(x).x[/tex], i.e. write the equation of the tangent line in terms of x and [tex]f'(x)[/tex].
So you need a point where [tex]f(x) = g(x)[/tex]
So: [tex]x^2 + 4 = (2x)x[/tex]
The problem did not say "tangent at (0,0)".
First, distinguish between the variable, x, and the x-value of the point of tangency. Let's call the x value at the point of tangency x0. Then the derivative at that point is 2x0 and so the tangent line has equation y= 2x0x. In order to be a tangent, that line must touch the parabola at x0: at x= x0 we must have y= 2x02= x02+ 4. Because of the symmetry, there are two lines through (0,0) tangent to y= x2+ 4
