How is the force in the Y direction developed in a simple laminar flow?
The discussion centers around the development of forces in the Y direction within a simple laminar flow of a Newtonian fluid. Participants explore the definition of viscosity, the behavior of the stress tensor, and the conditions under which forces act in different directions in the fluid.
  • One participant defines viscosity in terms of a fluid between two plates and presents a formula involving shear stress and velocity gradient.
  • Another participant challenges this definition, stating it is naive and emphasizes the molecular level analysis of viscosity in liquids and gases.
  • There is a discussion about the symmetry of the stress tensor, with some participants asserting it must be symmetric for non-rotating fluids, while others argue it is always symmetric regardless of rotation.
  • Concerns are raised about the existence of a normal force in the Y direction (Fy) when there is no vertical velocity, leading to confusion about the implications for shear stress (Sxy) and normal stress (Syx).
  • One participant expresses difficulty reconciling the condition that Fy = 0 with the assertion that Sxy = Syx, given that Syx appears to be zero.
  • Another participant asserts that Sxy is not zero, contradicting the previous statements about normal stress.
Participants do not reach consensus on the definition of viscosity, the behavior of the stress tensor, or the conditions under which forces in the Y direction develop. Multiple competing views remain, particularly regarding the implications of shear stress and normal stress in the context of laminar flow.
There are unresolved assumptions regarding the definitions of viscosity and stress, as well as the conditions under which forces act in different directions within the fluid. The discussion reflects a range of interpretations and understandings of fluid mechanics principles.
TFH
RE: non-compressible, laminar flow, Newtonain fluid.
Viscosity is often defined by looking at a fluid between two plates with the upper plate moving at a small velocity relative to the lower plate. The plate moves in the x direction and a velocity gradiant is created. Viscosity is then defined as:
Fx/Axz= Sxy = mu dVx/dy.
Fx = force between adjaycent fluid layers in the x direction.
Axz = area between the fluid layers
Sxy = stress in the direction of the force (x) where y is the direction of the normal to the area.
mu = viscosity
dVx/dy = Velocity gradient in the y direction.
This is the standard way texts define viscosity (unless I've messed it up!).
Next this idea is generalized to multiple dimensions and the stress tensor is defined. This is where I need help. It is argued that for non rotating fluids that the stress tensor must be symmetric. In particular Sxy = Syx. I see this in one sense. Usually this idea is arrived at by noting that a small element would develop an infinite torque or moment if it was not symmetric...okay good. BUT:
Finally my problem: In the simple example, how does a force in the Y direction develop. How does a normal force to the direction of fluid flow, Fy, exist. By definition of a fluid, if Fy exists, the fluid must shear...Any help or reference would be most appreciated.
That is not the definition of viscosity. And if it is, it is a naive one. Viscosity comes from the molecular level analysis in liquids, and from rotational and vibrational non equilibrium in gases.
The stress tensor is symmetric always, despites it is rotating or not. The symmetry of the stress tensor lies on the fact that each fluid particle is in rotational dynamic equilibrium .
I don't see your point. In your problem Fy=0, because there is no vertical velocity. You don't have any normal stress normal to the xz plane.
Clausius2 thanks very much for your reply.
Okay. I just used something basic provided by Bird, Stewart, and LIghtfoot Transport Phenomena and Lectures on Physics by Fynman et. al.
Okay.
My difficutly arises exactly because I too think Fy = 0. However if it does, then I don't see how Sxy = Syx because Syx = 0. And
Sxy = mu dVx/dy.
I don't understand what you mean. Here Sxy is NOT zero.
  • · Replies 35 ·
10K
9K
  • · Replies 48 ·
