Connect Multiple Devices with One Switch: An Electronics Question
  • Thread starter Thread starter Jelfish
    Multiple Switches
The discussion revolves around connecting multiple devices to a single signal source using a switch. Participants explore options for creating a switching mechanism that allows for seamless transitions between devices without needing to manually change connections. The scope includes practical electronics solutions and product recommendations.
  • One participant inquires about creating a switching box for a tool that outputs signal information through a serial cable, expressing a preference for a solution that does not require powering the switch.
  • Another participant suggests that the feasibility of the solution depends on various factors, including the specifications of the signal source and the devices, and asks for more information such as datasheets and signal characteristics.
  • It is mentioned that if the source and destinations have matching impedance (e.g., 50 Ohms), a splitter could be used, but additional details about the signal type (digital or analog) and bandwidth are needed for a more tailored solution.
  • Several participants note that a rotary switch, specifically a 6-pole 2-position switch, could be a suitable solution for the original inquiry.
  • One participant mentions that pre-made boxes with appropriate connectors and switching options are available for purchase at a low cost.
  • Another participant provides a suggestion to search for specific types of switches online, indicating that they are relatively inexpensive.
Participants generally agree on the potential use of a rotary switch and the availability of pre-made solutions, but the discussion remains unresolved regarding the specific requirements and configurations needed for the switching mechanism.
The discussion lacks detailed specifications about the signal characteristics and the devices involved, which are crucial for determining the best switching solution.
Individuals interested in electronics, particularly those looking to connect multiple devices to a single signal source or seeking practical solutions for switching mechanisms in electronic setups.
Jelfish
I'm not very experienced with electronics so this might be a simple question:
I have a tool that outputs signal information through a serial cable. I have two devices that connect with it, so I physically pull the plug and switch connections when needed. However, I would like to create a box with all three things connected and switch between the destinations with one switch. However, since there are several pins in use, I'm not sure how to do this without actually using a switch for each pin. Is there an easy way to do this? I would prefer to not have to power this switch also.
Thanks!
The answer depends on a number of things. Can you post more info (datasheets?) about the signal source and the two devices that monitor the signal?
Like, if the source and destinations are all 50 Ohms, then you can use a 50 Ohms splitter with a known loss to split the signals, and then just adjust your gain at the two receiving ends to account for the constant loss.
Is the data flow all one way, with no return information? Is the signal digital or analog? What is the bandwidth?
You have lots of options, we just need more info in order to be of help.
Thanks berkeman.
It turns out that I don't need this anymore. However, what I was looking for was something like a rotary switch, specifically a 6-pole 2-position.
Thanks anyway :)
Jelfish said:
Thanks berkeman.
Thanks anyway :)
You can get a box all made up with connectors and and appropriate switching for almosts any I/O port for a few dollars.
Really? Are you referring to a particular store or somewhere online? This may be useful in the future. Perhaps I should ask the local electronics shop.
  • · Replies 49 ·
  • · Replies 31 ·
