Object dropped from plane velocity problem
  • Thread starter Thread starter yankee
    Plane Velocity
The problem involves a plane dropping a hamper of medical supplies from a height of 3680 meters with an initial horizontal velocity of 136 m/s. The vertical motion is governed by gravitational acceleration at 9.8 m/s². The overall velocity of the hamper upon impact with the ocean is calculated using both horizontal and vertical components. The final velocity is determined to be approximately 268.6 m/s vertically and 136 m/s horizontally, resulting in a total magnitude of approximately 307.5 m/s when both components are combined using the Pythagorean theorem.
  • Understanding of free-fall physics and gravitational acceleration
  • Familiarity with kinematic equations for vertical motion
  • Knowledge of vector addition for calculating resultant velocity
  • Basic algebra for solving equations
  • Study the kinematic equations for projectile motion
  • Learn about vector decomposition in physics
  • Explore the effects of air resistance on falling objects
  • Investigate real-world applications of free-fall problems in aerodynamics
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of objects in free fall.
yankee
A plane drops a hamper of medical supplies from a height of 3680m during a practice run over the ocean. The plane's horizontal velocity was 136 m/s at the instant the hamper was dropped. The acceleration of gravity is 9.8m/s^2. What is the magnitude of the overall velocity of the hamper at the instant it strikes the surface of the ocean? Answer in units of m/s.
Please help- I don't know where to start or what formla to use!
I'm pretty sure the speed of the plane is irrelevant since the hamper was dropped vertically and thus did not have an initial vertical velocity. Assuming this is correct, this is just a classic free-fall problem using the equation
[itex]v_f^2=v_i^2+2ad[/itex]
Here d is the height, a is gravity, and vi is zero. Putting in these variables and then their values, the answer would be:
[itex]v_f=\sqrt{2gh}=\sqrt{(2)(9.8)(3680)}=268.6 \frac{m}{s}[/itex]
Josh
kreil, I disagree. I don't see any way to drop something from an airplane, negating the horizontal speed of the airplane. The speed of the airplane is important since the hamper will have that initial horizontal speed. You have two equations: vertical acceleration is -9.8 so vertical speed is vy(t)= -9.8t and vertical height is y(t)= -4.9t2+ 3680. Set that equal to 0 and solve for t to find the time when the hamper hits the water. Use vy(t)= -9.8 t to find the horizontal velocity at that point.
Horizontal acceleration is 0 so the hamper will still have horizontal velocity 136 m/s when it hits the water. Use both horizontal and vertical velocities to find the "magnitude of the overall velocity of the hamper at the instant it strikes the surface of the ocean".
