Thread Closed
Is a filament lamp an ohmic device?
Share Thread Thread Tools
Oct4-06, 07:58 AM   #1
Mo
From wikipedia:
Metallic and nonmetallic resistors are called ohmic devices, because they obey Ohm's Law, at least within certain limits of voltage and current
A filament lamp obeys ohms law within certain limits of voltage and current so does that mean it is an ohmic device?
Also from wikipedia:
A light bulb is an example of a non-Ohmic device because the current flow heats the bulb, and its resistance depends on temperature.
Sounds reasonable as well.
Im inclined to believe the second quote since there are only a few values that the filament lamp will be ohmic where as there are a lot more it won't.
Would appreciate a definite answer though
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct4-06, 11:04 AM   #2
Mentor
The filament obeys Ohms law at any particular instant in time. It is true that the resistance increases as the filament heats up, but at any particular instant in time, V=IR. I don't necessarily agree with the way wikipedia labels the filament non-Ohmic. That's a little misleading. But then again, I've never heard the term "Ohmic" before either.
Oct6-06, 12:45 PM   #3
I think it is just a matter of definition. Some definitions of Ohm's law are confusing. Some books say it is an ohmic device if it follows ohms law and has a constant resistance. Still V=IR it is just that R changes.
Suppose we had some a battery with emf of V. There is a resistor with R. Then the power would be:
[tex]P=Vi=\frac{V^2}{R}[/tex]
The result of a changing resistance is a changing power. I mentioned power because for non-ohmic devices the power change could mess with circuitry. I mean we turn something on, it has one power and after it heats up it has another. For some situations that could mess stuff up and since the resistance changes infetismally with temperature it doens't have constant resistance. The changing R by some definitions means that is isn't an ohmic device.
Thread Closed
Thread Tools
Similar Threads for: Is a filament lamp an ohmic device?
Thread Forum Replies
Ohmic Or NoN ohmic Introductory Physics Homework 3
I=kV^n filament lamp hnc assignment Engineering, Comp Sci, & Technology Homework 1
Current/Voltage relationship for a filament lamp? Introductory Physics Homework 10
help listing non ohmic devices Electrical Engineering 2
Lamp filament Introductory Physics Homework 8
