Can Ice Be Solid Enough to Create a Workable Sword?
  • Context: High School
  • Thread starter Thread starter Gara
    Ice
The discussion centers around the feasibility of creating a workable sword from ice, exploring the limits of ice density, the effects of rapid freezing, and the implications of using different cooling methods. Participants consider both theoretical and practical aspects of this concept.
  • Some participants suggest that ice can be compressed to increase its density, potentially allowing for the creation of a sword, but note that it would likely be brittle.
  • Others propose that very high pressure or rapid freezing methods, such as using liquid nitrogen, could enhance the density and structural integrity of ice.
  • A participant questions the effects of using liquid helium for freezing and seeks information on the differences between fast and slow freezing processes.
  • Concerns are raised about the practicality of an ice sword, including its weight and brittleness, which could limit its effectiveness as a weapon.
  • One participant mentions that astronomers have theorized about water becoming metallic under extreme pressure, raising questions about the properties of such a state.
  • Humorous remarks are made about the potential uses of ice as a weapon, including references to pop culture and fictional scenarios.
Participants express various viewpoints on the feasibility and practicality of an ice sword, with no consensus reached on the effectiveness or usability of such a weapon. Multiple competing ideas about the properties of ice under different conditions remain unresolved.
Limitations include the dependence on specific conditions such as pressure and temperature, as well as the unresolved nature of the effects of rapid freezing versus slow freezing on ice structure.
Gara
snow can be compressed into ice. what is the limit to how solid ice can be? could it be made dence enough to be used as a workable sword?
Ice has a density slightly less than water. You probably could make a sword, but it would be quite brittle.
at very very high pressure you could make it more dense than water, its also possible if you freeze it very quickly, with say liquid nitrogen, this cause it to solidify much faster and not form normal ice crystals.
how about liquid helium to freeze it?
where can i read about if its frozen fast its different to freezing slowly?
am i wrong in thinking high pressure makes heat in the pressureized object?
Liquid helium should have the same effect as liquid nitrogen (they'd be within a few degrees kelvin of each other). Try searching for super freezing or something like that. I've only heard of it second hand, but what i heard is that it is sometimes used as an instant freeze technique for vegetbales, to prevent the destruction of the cell structure (and thus taste) when freezing them. But again this is only second hand that i heard it, so i can't confirm its validity.
Also while that is true in gases at constant volume, if i remember from chemistry correctly the temperature change inliquids and solids is far below negligible, not enough to actually be of any significance beyond theory.
edit: i just found a site with some notes on supercooling vegetables, the key point being that it prevents the formation of ice crystals: http://www.msu.edu/course/fsc/229/Notes/Lecture%2024.htm [/URL]
Liquid nitrogen boils at 77K, is pretty cheap and can be found relativly easily. Your local doctor may have some/know where to get some, as it is used for freezing off warts etc. You will need a container, and polystyrene works well for this. Try and avoid being in an unventalated area with it (eg a lift) as you will suffocate as the nitrogen displaces the oxygen in the air.
Liquid helium, on the other hand, is very expensive (since it only makes up 0.0005% of the atmosphere, compared with nitrogen which makes up 78%, and boils at around 3.7K). It also need considerably less energy than nitrogen to evaporate, which makes storage a problem. You won't be able to use liquid helium unless you can get access to ascience department of some sort and a trained lab-worker.
Anyway, what do you want an ice sword for? Is it so you can stab someone and "watch the evidance melt" like in that MOP song?
Actually the effects of being stabeed by a weapon that is 77 K would be somewhat interesting, rather than cauterizing as a hot blade would the ice blade would cause instant frezzing of the nearest area of the body, with the cold spreading quit rapidly, until the entire body is uniformly frozen and then begins to thaw. Scary thought.
However making a sword this wake would be rather useless if only because the ice would be very heavy. If you tried to make the blade thinner it would probably be too brittle to be effective.
According to some astronomers trying to model the interior of Neptune, water can be made into a metal, given enough pressure.
Hmmm. A sword? What is it you're up to? Wasn't there a murder mystery about killing someone with an ice weapon so that the murder weapon simply melts away?
if i wanted to kill some one with ice i'd just use an ice block as a mace weapon, or a giant iceical.
water as a metal huh... would it still be transparent? I am guessing no.
but an ice sword would be cool to have*
*haha gara made a funny!
Yes, an ice sword would have to be cool.*
*haha zooby funnied a maid
13K
  • · Replies 22 ·
