Eigenvalue for DC motor convergence rate
The discussion focuses on determining the control voltage for a DC motor to ensure that the speed, denoted as w, converges to a constant reference input w* with a specified convergence rate defined by eigenvalues L1 and L2. The governing equations provided are J(dw/dt) = K1*i - T and L(di/dt) = -R*i - K2*w + u, where J represents the inertial moment, T is the load torque, R is resistance, and K1 and K2 are constants. The main challenge highlighted is finding the convergence rate based on the desired eigenvalues.
  • Understanding of DC motor dynamics and control theory
  • Familiarity with eigenvalues and their role in system stability
  • Knowledge of differential equations related to electrical circuits
  • Basic concepts of control voltage and its impact on motor speed
  • Research the application of eigenvalues in control systems for stability analysis
  • Study the derivation of control voltages in DC motor systems
  • Learn about the role of the inertial moment (J) and resistance (R) in motor dynamics
  • Explore numerical methods for solving differential equations in motor control
Electrical engineers, control system designers, and students studying motor dynamics and control theory will benefit from this discussion.
pcming
Hi,
I have troubles solving this question:
Given the general DC motor governed equation, find the control voltage such that the speed w tends to constand reference input w* and the convergence rate is determined by the desired eigenvalues L1 and L2.
I think it's easy to find the control voltage to the speed w. However I don't know how to find "convergence rate" which is determined by the desired eigenvalues. Can anyone give me some suggestions? Thanks.
pcming said:
Hi,
Can you give us the "general DC motor governed equation"?
AM
Hi Andrew,
here it is:
J(dw/dt)=K1*i-T
L(di/dt)=-R*i-K2*w+u
where J is the inertial moment, w is motor speed, T is load torque, R is resistance, i is current, K1 and K2 are constant, and u is the input voltage.
Thank for your reply! Hope you know how to do it.
9K
