Would an Object Fall Straight Through a Hole in a Spinning Planet?
  • Context: Graduate
  • Thread starter Thread starter Dmstifik8ion
    Hole Planet Spinning
The discussion revolves around the hypothetical scenario of an object falling through a hole in a spinning planet, focusing on the effects of planetary rotation on the object's trajectory and the nature of its motion. Participants explore theoretical implications, gravitational effects, and the dynamics of motion in a rotating reference frame.
  • Some participants propose that an object released from the surface of a rotating planet would not travel straight to the opposite side due to the planet's rotation affecting its trajectory.
  • Others argue that the object retains the horizontal momentum of the surface from which it was released, suggesting it would enter a type of orbit around the planet's center of gravity.
  • A participant notes that the trajectory would result in the object returning to a location offset from its original position due to the planet's rotation during the fall.
  • There is a discussion about whether the time required for the object to return to the surface would remain constant across different rates of planetary rotation, with some suggesting it would not be constant.
  • Another participant clarifies that the motion would not be a typical orbit but rather harmonic motion, as the center of gravity would be at the center of the ellipse formed by the object's path.
Participants express differing views on the effects of planetary rotation on the object's trajectory and the nature of its motion, indicating that multiple competing perspectives remain unresolved.
Limitations include assumptions about the ideal conditions of the hole and the neglect of factors such as heat, pressure, and construction difficulties. The discussion also does not resolve the mathematical implications of the motion described.
This discussion may be of interest to those exploring concepts in physics related to gravity, motion in rotating frames, and theoretical scenarios involving planetary dynamics.
Dmstifik8ion
Ignoring the intense heat and pressure of subterranean environments, the difficulties of constructing a hole under such conditions, drag and friction, etc:
Only a hole through the axis of rotation will provide a straight trajectory or one the passes through the exact center of a spinning planet, however;
Would the trajectory (determined entirely by the planets gravity and surface rotational momentum alone) of an object released at any point on the surface of a rotating planet bring it invariably to rendezvous with the opposite (half way around) side of the sphere?
In other words:
If a hole of suitable size to permit my passage suddenly opened up beneath me, would I travel to the opposite side of the Earth?
Astronomy news on Phys.org
I don't have a rigorous answer but my take on it is no.
Consider that two planets of the same mass and radius could easily have very different rotational speeds. So, while the object is falling at the same rate in both, one planet might turn only .1 degree while another might turn 20 degrees. Without bothering to do the math, we can see that the falling body will not be affected by this rotation, thus they cannot possibly both come out in the same place.
My thought was that the object when released would have the component "horizontal" momentum of the surface from which it was released. This horizontal component of its initial vector would cause the object in free-fall to "orbit" the center of gravity of the planet.
(Rotational velocities exceeding gravitational accelleration would not be permitted as this would change the figure of the planet accordingly, that is a planets surface can not withstand an angular momentum greater than the acceleration of gravity without becoming a satellite).
I hope you can appreciate that I am not trying to change the rules as this discussion progresses. This is only intended as a clarification of my original hypothesis. With apologies I have edited the original question in italics.
However I do have another but related question:
A faster rate of rotation would increase the perigee of the "orbit" but would the time required to return to the (opposite?) surface remain constant for any rate of rotation within planetary limits?
That's exactly correct. If you don't hit the sides fo the hole (let's say the hole continues to "open up" under you, or ahead of you as you fall), then you will drop into an orbit lower than the surface. You would return to about the same place you fell through, though planetary rotation would effect your location of return to the surface. Let's say you fall through from the equator, at midnight. You would be movign about 1000 m/hr when you begin infall. This would drop you into a highly elliptical orbit which would bring you back to nearly the same location from which you fell; midnight (the point on the surface farthest from the sun). But, if the trip took you a couple of hours, you would find yourself popping up in a town about 2000 miles west of where you fell through.
No, the faster orbit is in fact a "higher" orbit, having the same apphelion but a higher semimajor axis (or lower foci), so it would take longer, (because the square of the period is proportional to the cube of the semimajor axis).
Yes, but it would not be a typical Orbit. in a standard orbit, the object follows an ellipse with the centrer of gravity of the planet at one focus of the ellipse. In this case the center of gravity will be at the center of the ellipse. What you get is harmonic motion.
First off, this "orbit" would have two "perigees". As it will pass the center of the Planet twice, once on its trip to the "opposite" side and again during the return trip.
And yes, the time would remain constant. If fact, it stays the same right up to the point where the rate of rotation causes a speed at the surface equal to orbital speed.
Thanx Janus, LURCH, and DaveC426913,
Obviously a subterranean "orbit" wound not be geosynchronous, what was I thinking? . . . don't answer that! I'm off with my shovel now; wish me luck!
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 30 ·
