How high does a projectile go when fired upward at 58.8 m/s for 1.5 seconds?
  • Thread starter Thread starter KingNothing
    Projectile
The problem involves determining the height of a projectile fired straight up with an initial velocity of 58.8 m/s after 1.5 seconds. The context is kinematics, specifically focusing on motion under constant acceleration due to gravity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need for additional information, such as the object's size and mass, to consider factors like wind resistance. Some suggest that for a high school physics problem, only the effect of gravity is relevant. Various approaches to solving the problem are mentioned, including using kinematic equations and breaking the problem into parts.
Participants are exploring different methods to approach the problem, with some providing guidance on using kinematic equations. There is a recognition of the importance of understanding the relationships between distance, time, and speed. However, no explicit consensus or final solution has been reached.
Some participants express frustration over memory lapses regarding their previous calculations, indicating a potential lack of clarity in recalling the problem-solving process. The original poster did not provide their work, which has led to challenges in identifying errors.
KingNothing
I am not sure how to do this. I keep coming out with the wrong answer.
"a projectile is fired straight up at an initial velocity of 58.8 m/s. How high above the ground is it 1.5 seconds after firing?"
You have not supplied enough information. You would need to know the size, mass of the object to factor in wind resistance and kentic energy along with the effect of gravity.
This should be in the homework help section.
Since you didn't show your work, we can't tell where you went wrong.
Ignoring the complication of air resistance, this is a straightforward application of the kinematics of constant acceleration:
[tex]y = y_0 + v_0t + \frac{1}{2}at^2[/tex]
For the sake of a high school physics problem (which this appears to be), none of that is relevant (except the effect of gravity, which is known).
I always split these problems into two parts for easier swallowing. First, use the deceleration due to gravity to find the speed of the projectile after 1.5 sec. Then multiply the time by the average speed.
Nothing wrong with that. :smile: For many students, it's the best approach.
I encourage students who are comfortable with the algebra to know (or derive!) the relationships between the three variables: distance, time, and speed. One should be able to produce at will a formula connecting any two of these variables (for constant acceleration). And understand how to apply them.
Yeah, I think that's the approach I ended up taking (I had to do this problem today, but sadly I didn't get to check this forum in time to see if there were any replies.)
Now this is really just pissing me off. I can't remember how I did it. AHHH! I hate that feeling. I want to say what I got for an answer to see if you all think its reasonable, but I can't even remember. If its not too much trouble, could someone give me a good or reasonable answer? I don't know why my memory chose to fail me now.
Scratch the above idea...let me see if I can remember.
What is y in that equation?
y is referring to distance or displacement. [itex]y_0[/itex] is the initial displacement, which in this case is zero.
I got D=77.175m. Can anyone confirm this?
That agrees with my answer.
