What Does a Non-Zero Y-Intercept on a Force vs. Acceleration Graph Indicate?
  • Thread starter Thread starter Soaring Crane
The discussion centers around the interpretation of a non-zero y-intercept in a force vs. acceleration graph. The original poster questions the significance of this intercept, particularly in relation to the expected value of zero force at zero acceleration, and whether it indicates an overlooked source of force in their data collection.
  • Exploratory, Assumption checking
  • Participants explore the implications of a non-zero intercept, with some suggesting it may indicate measurement errors or the influence of frictional forces. Questions arise regarding the magnitude of the intercept and the values of force and acceleration used in the analysis.
The discussion is ongoing, with participants providing insights into potential sources of error and the physical implications of the observed data. There is a focus on understanding the relationship between force and acceleration, particularly in real-world scenarios where friction may play a role.
Participants note that all force and acceleration values are less than 1.0 N and 1.0 m/s², and there is a mention of an attempt to create a frictionless setup, raising questions about the presence of frictional forces as a source of error in the measurements.
Soaring Crane
My question concerns the y-intercept of the force vs. acceleration graph. When I plotted my data, the regression line had an intercept that was not 0. What does this signify? I know that the intercept is the amount of force when the acceleration is 0 m/s^2. Shouldn't it be 0 N at 0 m/s^2? Does this mean there was a source of force that I neglected to take account for while recording the values for the graph?
Thanks.
Most likely!
Force is strictly proportional to acceleration.
Just how non-zero is it? Could it be an indication of measurement errors?
Consider the case if the graph was drawn a vs F.
The x-intercept will indicate that some non-zero force was necessary to start the acceleration of the object - a tipical real life situation we find in order to overcome the ever present frictional forces.
The intercept was about 0.0051 (N).
What are the typical magnitude of your data values?
Which values? The a values or the F values?
All the force and acceleration values are less than 1.0 N and 1.0 m/s^2, respectively.
My smallest F value is 0.0961 N and greatest is 0.446 N.
My smallest a value is 0.188 m/s^2 and greatest is 0.869 m/s^2. The smallest F value corresponds with my smallest a value, and the greatest F value corresponds with my greatest a value.
A frictionless setup was organized (or was attempted to be organized), but it is possible to still have frictional forces as a source of error?
Indeed there can, and will be!
In your case, the force discrepancy is about a twentieth of your least value, that is most likely the effect of friction showing up.
  • · Replies 24 ·
