| Thread Closed |
Calculate the force of a spring |
Share Thread | Thread Tools |
| Oct7-06, 04:33 PM | #1 |
Introduction and Question:
You are designing a delivery ramp for crates containing exercise equipment. The crates weighing 1490 N will move at a speed of 1.80 m/s at the top of a ramp that slopes downward at an angle 21.0^\circ. The ramp exerts a kinetic friction force of 540 N on each crate, and the maximum static friction force also has this value. Each crate will compress a spring at the bottom of the ramp and will come to rest after traveling a total distance of 7.60 m along the ramp. Once stopped, a crate must not rebound back up the ramp. Calculate the force constant of the spring that will be needed in order to meet the design criteria. I am stuck on this only because I cannot extract from this data the distance the spring compresses. Can someone please offer some insight? |
| Oct7-06, 06:10 PM | #2 |
Admin
Possible one is to use two equations, with two unknowns, k and x.
One is the force equation and the spring force, Fsping = kx, and the other equation is an energy equation, in which the spring stored energy is Esping=1/2 kx2. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculate the force of a spring
| How to calculate g-force in a Class 2 rocket | General Physics | 0 | ||
| Two blocks touching with one applied force...how to calculate force of one on another | Introductory Physics Homework | 3 | ||
| Calculate distance from force HELP!!! | Introductory Physics Homework | 1 | ||
| calculate force | Introductory Physics Homework | 6 | ||
| how to calculate the magnitude of force when some force is applied at far away distan | Mechanical Engineering | 1 | ||
