Thread Closed
Pressure and flow rates
Share Thread Thread Tools
Oct7-06, 07:02 PM   #1
There is a pipe whose diameter narrows smoothly from 10cm to 5.0cm. The pressure at where this pipe's diameter is 5cm is 50kPa. Given water's density of 1000kg/m^3, and a flow rate of 5.0L/s, what is the pressure at the point where the pipe's diameter is 10cm?
First the continuity equation:
Q=Av
0.005L/s=[pi(0.05/2)^2]v
v=2.546m/s
Then, Bernoulli's equation:
Substitute v1 for A2v2/A1
P1=50000+(.5)(1000)(2.564^2-[(pi*.05^2)(2.564)/(pi*.1^2)])
I left the potential energy out of the equation because it is negligible givien the number of significant figures we have. Even though I did the calculation with adding potential energy it is still wrong.
So I got 79993Pa. I know it is very wrong but I cannot check it since I don't have the answers. Any help please?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct7-06, 08:32 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by laminar
Q=Av
v=2.546m/s
Your approach is difficult to follow because you are plugging in numbers too soon. You have made a simple arithmetic error. I am not sure what you did. The second 2.564 should be squared but that does not explain the error.
Do the analysis first then plug in the numbers at the end.
You appear to be using Bernoulli's equation (ignoring gravitational potential):
(1) [tex]P_1 + \frac{1}{2}\rho v_1^2 = P_2 + \frac{1}{2}\rho v_2^2[/tex]
and:
(2) [tex]v_1A_1 = \frac{dV}{dt} = v_2A_2[/tex]
so: [itex]v_2 = v_1A_1/A_2[/itex]
and from (1) then:
[tex]P_2 = P_1 + \frac{1}{2}\rho v_1^2 - \frac{1}{2}\rho \frac{v_1^2A_1^2}{A_2^2} = P_1 - \frac{1}{2}\rho v_1^2\left(1-\frac{A_1^2}{A_2^2}\right)[/tex]
So far, this is what you have done. Now plug in your numbers:
[tex]P_2 = 50000 + .5 * 1000 * 2.546^2(1-.25) = 50000 + 2400 = 52,400 \text{kPa}[/tex]
AM
Thread Closed
Thread Tools
Similar Threads for: Pressure and flow rates
Thread Forum Replies
question on pressure, volume and rates of change Introductory Physics Homework 2
rates of pressure and volume change Introductory Physics Homework 1
Determine Force/pressure from air flow? Mechanical Engineering 10
converting pressure to flow rate Introductory Physics Homework 4
