How Do You Calculate Mass Percent in Redox Titrations?
  • Thread starter Thread starter loadsy
    Redox
The discussion revolves around calculating mass percent in redox titrations, specifically involving the compounds Au2(C2O4)3 and Li2(C2O4), as well as a metal oxalate complex M2(C2O4)3. Participants seek assistance with the steps required to solve these titration problems, including the necessary chemical reactions and stoichiometry involved.
  • Homework-related
  • One participant describes a lab scenario involving the titration of a contaminated sample and seeks help in determining the mass percent of Li2(C2O4) in the mixture.
  • Another participant emphasizes the importance of understanding the reactions and suggests specifying the reactions involved and using stoichiometry to solve the problem.
  • A participant expresses confusion about how to convert moles to grams for the mass percent calculation and acknowledges the need for further clarification.
  • One suggestion involves setting up a system of two simultaneous equations to account for the total mass and the number of moles of oxalates from the titration.
  • A participant reflects on their understanding after receiving advice and indicates they will return with further questions if needed.
  • Another participant presents a similar problem involving an unknown metal oxalate complex and discusses their approach to finding the identity of the metal M, including calculations related to molar mass.
  • A later reply corrects a participant's terminology from "number of moles" to "molar mass" and provides a formula to relate the molar mass of the metal and oxalate.
  • One participant acknowledges a previous mistake in their ratio understanding and expresses relief at clarifying the correct ratio for the compounds involved.
Participants generally agree on the need for stoichiometric calculations and the importance of understanding the underlying chemical reactions. However, there is no consensus on the specific steps to take or the correctness of individual approaches, as some participants express confusion and seek further clarification.
Participants mention the necessity of understanding the reactions and stoichiometry involved but do not provide complete definitions or assumptions, leaving some steps in the calculations unresolved.
loadsy
Hey there, recently we just did a lab in Chemistry 101 on "Redox Titrations." I'm now working on the lab writeup but was hoping that someone may be able to help me with this question I am currently stuck on. It asks the following:
A sample of Au2(C2O4)3 is contaminated with Li2(C2O4). An acidified 0.2000g sample of this mixture requires 18.12mL of 0.02593mol/L KMnO4 to reach the equivalence point. In acidic solution, the oxalate ion is protonated and titrated with MnO4^- as in the laboratory experiment. Determine the mass percent of Li2(C2O4) in the sample.
Note: The metal ions are not oxidized by the permanganate ion. However, all of the oxalate bonded to the metals reacts completely with the permanganate ion.
Now I know you can start off the problem by finding the number of mols and then from that finding the molar mass of Li2(C2O4). But from there what do I do? Thanks a lot to anyone who can help me. :D
You need to understand which reactions are going on, please specify these reactions, even more, use the stoichiometry of the equations to solve the problem.
Hmmm well I know the reactions between the substances and understand what is taking place. It's just the steps in between I'm having trouble understanding because for a mass percent equation you need the substances in grams and multiply by 100 to determine it, and I'm not sure how to go about doing so. Thanks for the advice though.
You have to set up system of two simultaneous equations: one for sample mass (sum of masses of both substances), second for number of moles of oxalates (from titration).
Ahhh that makes a little more sense, and then after finding the answers to both of those equations I'll set up, I'll be able to find the mass percent of the Li2(C2O4)3 sample. I think I kinda get it now. Thanks for the help guys. If I have any further questions regarding this problem, I'll come back and ask.
Alright I've answered that last question, but I'm having problems on a fairly similar question. The question asks:
An unknown metal oxalate complex, M2(C2O4)3, reacts with KMnO4. The metal ion is not oxidized by KMnO4, however, all of the oxalate bonded to the metal reacts completely with KMnO4. Titration of an acidified 0.4556g sample of M2(C2O4)3 requires 28.42mL of 0.06049mol/L KMnO4 to reach the equivalence point. In acidic solution, the oxalate ion is protonated and titrated with MnO4^- as in the laboratory experiement. What is the metal M?
Now this question, like I said seems fairly identical to the other one. You start off by finding the number of mols of KMnO4 and from that, finding the number of mols of M2(C2O4)3, which I found to be 265.02g/mol. However, the question asks "What is the metal M?" I know you have to find the molar mass of what M actually is in the question, but how do I go about doing that? I've thought about doing it this way:
Since we know the ratio 2:3 I thought maybe finding the molar mass of (C2O4) and multiplying everything by 2 since it has a charge of 2-, and then dividing that answer by 3 since there is a charge of 3+. Does that make sense? Because after doing that I found the metal to be Nickel since it's closest in atomic mass. However, have I done this right or do I just need to go cry into my textbook for a minute and try again?
I suppose you meant 'molar mass', not number of moles.
Assuming you have calculated molar mass of the oxalate correctly:
2*(molar mass of the metal) + 3*(molar mass of oxalate anion) = 265.02
Molar mass of oxalate is easy to calculate, that leaves you with one unknown.
Hahaha yeah I did mean molar mass. I think it makes a little more sense, now. I had it is a 6:1 ratio and it came out completely wrong. 2:3 ratio is where it's at. :D
17K
17K
28K
